Q: What is the most practical configuration for running a network of Leviton devices/controllers & Vera 3?
DETAIL
I have a network of Leviton devices & controllers in my house.
I have struggled over the years and found that, for me, ControlThink was the best available solution for configuring it.
Vera 2 never worked well as the primary controller with my Leviton devices. However, I was able to get it to partially function as a secondary controller and I was able to live with that. The last time I touched the network configuration was probably Summer 2011.
When Vera 3 became available earlier this year, I upgraded immediately, but I only recently worked up the courage to try again.
I tried setting up the network with Vera 3 as the master. This was still a relatively painful process and the end result didn’t work very well. Much better than with the last time I tried … 18+ months ago. But, still some issues with delays & indicator lites not working properly.
Therefore, I bought the Viza RF+ Installer Tool usb controller, As other postings have said, this is a significant improvement. Using the Leviton Installer Tool software I was able to rebuild my zwave network and have it work well. I was, frankly, pleasantly surprised that I was able to rebuild the network and have it function properly with minimal frustration.
The final step was to take a deep breath and try to include my Vera 3 into the network. However, I have not been successful with this. I able to figure out how to include Vera 3 as a controller into the Installer Tool network. I can’t get the two to establish communication.
Here is a random list of questions on this complex topic:
Q: Is there a way/trick for including Vera 3 into a network that is configured with the Leviton Installer Tool?
Q: Should I try to set up the network by building the network with Vera 3 as the master, then including the Leviton Installer Tool as a controller? (please say no)
Q: Once the network is configured (if I ever get there), Should Vera 3 be the primary or a secondary network controller?
Q: Please confirm that I should use the checkbox “By default Vera should automatically configure devices” to prevent Vera 3 from overwriting the vendor-specific direct associations (terminology?) between the Leviton devices & controllers.
Q: Do I want to throw a Leviton VRCPG-0SG button controller into the maelstrom?
Thanks in advance!
Michael
