What do you do when are 4000 miles from your vacation home and you no longer can connect to Vera 2/ UI4? I know that my Wifi and router is working, because I can still access my FOSCAM…
Attached is the screen I get on MIOS. Non of the 4 offered options work.
Can you SSH to the Vera2 remotely? If it responds to SSH, you can try and login as root and issue the reboot command. Maybe it just needs to be bounced? I have had to do this on occasion.
