Vanishing Control
One of my Fibaro 2 x 1.5W switches seems to of vanished from Vera. I had two items set up on the switch, garden lights and outside lights.
The strange thing is that I notice Garden lights has vanished from vera and from my Authomation app, however if I use Imperihome it’s still showing (and it functions as expected).
What would cause it to vanish from two things but still be visible and controllable from another ?
This has been brought up several times on the forum. If you search for “fibaro missing” it will give you many results. Have a look at this thread:
http://forum.micasaverde.com/index.php?topic=10287.msg109595.msg#109595
  • Garrett
I’m not sure this is related to an update as I’ve not done one. Everything has been fine, but it just randomly vanished, however it still shows in one of the apps I use. I’ll do some more reading to see if anyone has had similar issues as looking through the threads they are a little different.
The other switches that I have which are the same are still showing all the switches as expected so its just this one switch.
Display your user_data with: http://:3480/data_request?id=user_data&output_format=xml and find the entries for the missing devices. Look for attributes like invisible or hidden. It won’t tell you what set the attributes but it could explain why the devices are not visible in the UI.
