Is there a [tt]dataType[/tt] for float?
Yes, there are several:
[ul][li]r4: 4 Byte float. Same format as float. MUST be between 3.40282347E+38 to 1.17549435E-38.[/li]
[li]r8: 8 Byte float. Same format as float. MUST be between -1.79769313486232E308 and -4.94065645841247E-324 for negative values, and between 4.94065645841247E-324 and 1.79769313486232E308 for positive values, i.e., IEEE 64-bit (8-Byte) double.[/li]
[li]number: Same as r8.[/li]
[li]fixed.14.4: Same as r8 but no more than 14 digits to the left of the decimal point and no more than 4 to the right.[/li]
[li]float: Floating point number.[/li][/ul]
Thanks for the quick reply.
An additional question:
Must the [tt]dataType[/tt] within [tt]…[/tt] match the [tt]dataType[/tt] in the JSON file?
Not necessarily, but it would be good programming practice. Use number in both places to be on the safe side.
Either number isn’t a float, or there is something wrong with the number parser for Luup variables/events, see http://forum.micasaverde.com/index.php?topic=6009.0.
Have you tried float? It’s possible that number is treated as an integer.
I’ll try float - but number seems to work if the first digit is 1 …
Maybe the parser doesn’t like 0.9 and prefers 9E-1?
Scene has event 'Cosmical dose rate goes above' [0.1] 'microSv/h'.
Setting DoseRateCosmical to 0.9 doesn't trigger the event.
Setting DoseRateCosmical to 1.1 does trigger the event ...
but number seems to work if the first digit is 1 ...
Maybe 0.1 and 0.9 are rounded to 0 and 1.1 is rounded to 1, so that’s why the event condition evaluates to true if DoseRateCosmical is 1.1.
It does work for [tt]EarthquakeMagnitude > 1.5[/tt]:
The event doesn’t fire for mag <= 1.5, but does fire for mag > 1.5.
Here are the results for float (the published DAD V0.13 BETA uses number):
An event should fire, if
E1-E3: DoseRate... > 0.1
E4 : DoseRateTotalWarning = 1
E5 : EarthquakeMagnitude > 1.5
E6 : EarthquakeDistance < 7500
Reset the variables:
DAD_ID = 16872
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateCosmical' , '0', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTerrestrial' , '0', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotal' , '0', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotalWarning', '0', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeMagnitude' , '0', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeDistance' , '10000', DAD_ID )
Now let’s set the variables:
DAD_ID = 16872
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateCosmical' , '0.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTerrestrial' , '0.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotal' , '0.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotalWarning', '1' , DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeMagnitude' , '1.6', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeDistance' , '100', DAD_ID )
Events E4 and E6 fire, events E1-E3 and E5 are missing.
Now let’s test [tt]norepeat 0[/tt]: Run the code from above once more
Result: No event fires, but all events should have fired.
Let’s change the variables a little bit:
DAD_ID = 16872
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateCosmical' , '1.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTerrestrial' , '1.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotal' , '1.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotalWarning', '0' , DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeMagnitude' , '1.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeDistance' , '101', DAD_ID )
Events E2, E3, E6 fire
DAD_ID = 16872
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateCosmical' , '2.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTerrestrial' , '2.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'DoseRateTotal' , '2.9', DAD_ID )
luup.variable_set( "urn:upnp-ap15e-com:serviceId:DAD1", 'EarthquakeMagnitude' , '2.9', DAD_ID )
Events E1-E3, E5, E6 fire …
One possible explanation could be that the event evaluator doesn’t know about floats …
MCV,
please provide a fix. Thanks in advance!
I found the piece of code where the comparison is made and I can confirm that all numeric values are converted to int, probably for performance reasons.
Knowing this, you could multiply every float value by 10, so instead of 1.5 you would have 15.
I will talk to Aaron to see if he can implement support for floating point values.
Thanks for digging into the source code and for confirming that currently there is no support for floating point values for Luup events.
I’ll leave DAD as it is and wait for a fix. I could change microSv to nanoSv, but there is no intuitive workaround for EarthquakeMagnitude (deciMagnitude? :-[).
Bug report:
http://bugs.micasaverde.com/view.php?id=1444
BTW, is [tt]norepeat 0[/tt] working as designed (event doesn’t fire if the new value is the same as the old value)?
IMHO, [tt]norepeat 0[/tt] should fire an event regardless of the previous value, otherwise two events with the same value (e.g., two earthquakes with the same magnitude) cannot be discerned.
I'll leave DAD as it is and wait for a fix.
The fix won’t be available in the next release version.
BTW, is norepeat 0 working as designed (event doesn't fire if the new value is the same as the old value)?
Yes, it’s working as designed, though you have a valid point. While the floating point thing isn’t hard/risky to implement, changing the norepeat behavior can break some older plugins and applications, so will require extensive compatibility testing.
[...] changing the norepeat behavior can break some older plugins and applications, so will require extensive compatibility testing.
Valid point. You could add a new keyword, e.g. [tt]refire 1[/tt] ([tt]repeat 1[/tt] would be a bad choice :)).
Edit:
New feature request: http://bugs.micasaverde.com/view.php?id=1445
