I am trying to recover from glitch exhaustion and ressurect my newest veras, my vera3 after bridging seemed to be normal for quite some time then all the icons turned generic with no controls (no on/off etc) vera lite (which I had tried unsuccessfully to bridge) also shows only generic icons, if I add a new device the icons for others of tha same type which had been generic now appear (though on V3 still without controls) until the next time I hit “reload” then all icons turn generic again. As I’ve heard very little on this problem in past I’m guessing it has something to do with bridging/having been bridged though it doesnt go away after separating units. Is there a fix for this which doesn’t require penetrating the time/space continuum?
PS: I have tried a hard factory reset with no change
Update: after a few minutes the controls do re-appear on v3 as well but same behavior, a re-load turns icons generic again
Update2: if I operate the switch when icons are generic all of that type will again show correct icon
OK, this is an odd one - condolences.
I wonder if you have browsed this thread:
[url=http://forum.micasaverde.com/index.php/topic,13521.0.html]http://forum.micasaverde.com/index.php/topic,13521.0.html[/url]
which was all about generic icons and bridged Veras (and, latterly, issues with unlinking Veras).
I’m wondering is the ‘unbridging’ has left a rift in space/time.
You might check the “foreign_master” tag of the machine’s “user_data” per the above thread.
[quote=“akbooer, post:2, topic:174694”]OK, this is an odd one - condolences.
You might check the “foreign_master” tag of the machine’s “user_data” per the above thread.[/quote]
Much appreciate the reply, I had read that thread but was hoping that someone might have learned more since then or found an easier way to restore order
A bit more information on this problem, It does not occur in android or chrome, only in IE and I am using ver9, it does not matter whether or not I use “compatibility view” the problem persists. Like it or not this is one of the most widely used browsers and Micasaverde would do well to make sure they are compatble.
The problem is completely resolved when you use chrome? I am having similar problems (http://forum.micasaverde.com/index.php/topic,14101.0/topicseen.html) and they are still occurring no matter what browser I am using.
Tried removing/adding the devices, no improvement there.
Also, I get a “command failed: invalid action” if I try and rebuild the network.
Has been like this for 3-4 days now :-\
Please see my new post at [url=http://forum.micasaverde.com/index.php/topic,15017.0.html]http://forum.micasaverde.com/index.php/topic,15017.0.html[/url]
