V1.1 arm disarm but not seeing devices
Hello
I installed, latest v1.1 from the marketplace with my vera3 and can arm/disarm using the plugin.
I am not able to see any of the devices/sensors that the powermax+ is monitoring/connected to. All I see in the vera dashboard is “Alarm Panel” and “Partition1 (Powermax)”. With disarm, I cannot seem to store the code, is this correct?
With the plugin, I can also download the logs. But thats it :frowning:
Guess I am missing something basic. Would appreciate any info on how to proceed.
Thanks in advance.
Did you read the wiki and follow the procedure to enroll PowerLink mode?
Answering my Q, turns out I was in standard mode, NOT Powerlink mode. Re-installed powerlink from panel and I can now see all the devices with the auto add/config.
Devices are shown with the little green man. ‘Tripping’ a sensor does not turn this to red. Think I need to go read something :slight_smile:
Whats the best way to cross check all the sensors to ensure they are all working from within the plugin/vera? Ideas greatly appreciated.
Thanks for this awesome plugin, I just need to learn how to use it!
[quote=“nlrb, post:2, topic:176070”]Did you read the wiki and follow the procedure to enroll PowerLink mode?[/quote] Thanks Yes.
Did a ‘walk around’ and while some sensors show up with the ‘red’ man, others remain green for some reason. The panel itself knows about this as I turned on the ‘chime’ and can hear it.
Could it be the interface in some way not reporting?
Thanks!
Hard to say without more information. I would need to see the log files. Sensor state changes should show up for all sensors almost instantaneous.
Let me know where I can email them. Will check on how to get them.
Please read the Introduction topic. That answers both of your questions.
