@home I have an ultraviolet (UV) water filter, together with other water purifying systems.
As you might know the UV filter works with a UV lamp. That lamp has a time life of around 10000hours and the only way to know if it is working or not is to confirm with a led it has on the power adaptor.
Since all the gear is installed at the machinery house I have no way to confirm if the UV lamp is working correctly without going to the… machinery house (I like to call the machinery house ;D).
Is there a Zwave appliance to tell Vera to tell me the UV lamp it’s not working?
You could use an Aeon Labs smart energy switch that gives you energy usage. I would think would able to see the difference in power usage when UV lamp goes out.
Thanks John! That really sounds to be an option. I suppose the power input with the lamp on should be much higher than just the power adapter with no lamp.
Actually the UV Light intensity degrades before the light goes out. You should NOT wait until the lamp dies … So measuring the power is the wrong thing to do. It will provide a “total failure” indication.
I have a digital UV meter to measure the strength of the light on my water purification system (Sanitron UV System 20Gal/min + digital monitor)
It’s currently reading around 70% (It was new in November with a reading of 100%). At this time I do not know if the decay, or, the resulting quality degradation is linear. I want to see how low it goes after 1 year. It has configurable alarm output (dry contact switch) that I could use to signal an alarm condition. I had not previously considered automating this … there are folks that have hacked up the Aeon door switch to replace the reed switch with an external switch closure that I could use as a Z-Wave sensor.
end[quote=“garrettwp, post:4, topic:171737”]The smart energy switch reads the power usage of the device plugged in. If the uv bulb dies the power usage should read 0.[/quote]If you have one lamp, that is correct. I’ve got two HVAC UV lamps per switch, along with some Lua and SND for the email notification if a lamp burns out, so I halved the wattage it monitors.
[code]
local lul_watts1=luup.variable_get(“urn:micasaverde-com:serviceId:EnergyMetering1”,“Watts”,197)
local lul_tmp = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, 197)
if (( tonumber(lul_watts1)<36 ) and (lul_tmp == “1”))
then
luup.call_action( “urn:upnp-ap15e-com:serviceId:SND1”, “SendMail”, { subject = ‘UV Bulb Burned Out’, body = ‘’ }, 158 )
return true
else
return false
end [/code]
