Using Z-Wave sensors for an alarm - how to improve resiliance
[quote=“RichardTSchaefer, post:185, topic:174399”]With the size you are talking about … you are talking a number of sensors … So you will have a significant investment in this project. And I am sure you will want to be proud of it, and not have to make excuses why things are now working as your family expects.
I personally do not think you will be satisfied with the Z-Wave Motion sensors that are available. Some folks live with their deficiencies. The Z-Wave part is a great idea … the motion sensors they attached to the Z-Wave suck … partially because of the design workarounds because of battery power. It makes Home Automation tricky.
You can always hook a wired Motion Sensor to a Z-Wave or DCS Wireless contact switch. It’s not an out of the box solution. Or connect it to something like an iTach to get 3 input channels via Wifi from a common area.[/quote]
Coming back on this notion that Zwave in unreliable for security setups (from a non owner of the Vera, just defining what I need yet)
Lets say you have a small appartement (Paris style, like 700sq ft) and you just need to check the main door and eventually a couple windows depending on how accessible they might be.
Then I guess you need to double the condition with a motion sensors to avoid having this thing go on if only 1 condition is met (just guessing here, tell me if I’m wrong).
What would then the best best way to switch the “alarm” on and off?
Lets say I need both the door and the motion sensor to complete the condition and trigger the alarm, what happens if one of the 2 devices loose the contact to the vera (no battery or else)?
If the alarm starts in the middle of the night (I was thinking 2 different Zwave battery juiced alarms), what will I need to do to shut off this nightmare off in case of incorrect triggering?
Thank you for your help,
almograve
Splitting this topic off, since it’s not related to the DSC thread it was posted in. Moving it back to the general security forum for discussion.
You could add a third sensor to your television… if it get’s lifted off the table it trips. At that point are you now sure someone is in the apartment!?!
If a sensor loses contact with the Vera, it won’t cause a Tripped condition.
Most big alarm companies rely on this technology (different frequencies) without big problems.
Try your configuration for a few weeks before setting up the siren. just have vera send you notifications via email or test for the test period.
[quote=“Bulldoglowell, post:3, topic:178716”]You could add a third sensor to your television… if it get’s lifted off the table it trips. At that point are you now sure someone is in the apartment!?!
Try your configuration for a few weeks before setting up the siren. just have vera send you notifications via email or test for the test period.[/quote]
65 inch TV, I’m not too woried :slight_smile:
you being sarcastic makes me think it might even ben too much to have 2 sensors?
I sure can’t rely on a motion sensor that could “see” movement for no reason…then I understand that a door or window sensors is much more reliable,
Thank you for the idea of setting this up without the alarms for a start,
it came off sarcastic, I was trying to be cute, Sorry!
You should be able to create your alarm scenes pretty easily with a handful of devices. Good luck
