Using Ramptolevel command
Im trying to create a “sunset” effect with Hue.
I’ve set up the condition to set the start colour and now need to set the fade. I believe I need to use the “startramptolevel” command is that correct ? I’ve played about with this but nothing happens. I’ve set the ramp level to 0 and set time 00:03:00 three mins. Is that the correct time format to use ?.
I’d like also like change the colour during the fade (the real fade will be longer), is there an elegant way to do this ?. I was thinking I’d just need to programme some other preset colours and change to those as I had over between different dim levels.
