I have energy reading appliance switches on my dryer, washer, and microwave (and more to follow). Using various plugins for countdown timers, combination switches, and variable containers, Vera now tells me the current state of the drying cycle. e.g. Off, Cooling, or Heating, based upon the wattage and duration.
This displays nicely on my phone with the Homewave app. My wife and I also get notified (via Prowl) when the cycle is complete, so we can empty the load etc.
Whist this is working well for me, each domestic appliance that I have set up requires a minimum of 6 virtual devices each (3 timers, 3 combination) and at least 6 scenes to operate them. This is a lot for each appliance. There must be a better or more efficient way of doing this. Does anyone have suggestions please of a plug-in or code that could replace the above complicated approach?
I think such a plugin would need to support at least 3 states, and each state would have a configurable power range and minimum duration to prevent it from falsely cycling between two states due to rapid power fluctuation that naturally occur. Would any of the existing plug-ins or LUA code help me reduce the number of virtual devices I currently have? I hope someone has suggestions. Thanks.
Example conditions that I currently use are:
Dryer:
Off: 0 to 4 watts; for 180 seconds
Cooling: 5 to 250 watts; for 90 seconds
Heating: 300 to 3000 watts; for 90 seconds
The scenes start and reset the timer so that the the “state” doesn’t change unless it has been in the new wattage range for a minimum of the required duration.
