Using PLEG how to reset a button press on a WDHA-12R Wayne-Dalton Gateway device
I have a WDHA-12R Wayne-Dalton Gateway device
I have it all paired up with the vera and the homelink in the car on button #2
I am using PLEG 6 to control the scene
PLEG Setup up
Triggers
Name Description
HomeLink2Pressed WD_Controller: scene number 2 is activated
Condition Name Condition Expression
HomeLink2 HomeLink2Pressed
HomeLink2LightOff HomeLink2 and (HomeLink2; Now > 0:02:00)
Conditions
Condition #of Actions Actions
HomeLink2 Immediate ? 1 Turn Garage Light On
HomeLink2LightOff Immediate ? 2 Turn Garage Light Off
This all works, lights come on when homelink button #2 pressed and lights go out 2 minutes later. However the HomeLink2Pressed Trigger never resets back to false in the PLEG status report always shows that it is true. At this point pressing homelink button #2 again and the scene will not work anymore. I have to physically go the WDHA-12 device and press button 1 or 3 to get the HomeLink2Pressed trigger state to go false.
PLEG Status Report after the 2 minute light turn off
HomeLink2Pressed WD_Controller: scene number 2 is activated true 2014-03-06 19:30:20.518 2014-03-06 19:30:10.258
Question how would one go about resetting the WDHA-12 Button #2 so it resets to false using PLEG?
ML
test to see if the button was just pressed
instead of:
use
HomeLink2 HomeLink2Pressed AND (HomeLink2Pressed; Now < 1:30)
I knew it was something simple, I learn something new here every day.
ML
Or you could have selected the Repeat option for the condition so that it will fire the actions even if it already true.
