Using JSON to store data in variable
I want to parse JSON. Can someone please help me?
I have to open this URL to get the response:
http://192.168.1.23/get/data/1
{"value":"1","key":"D13","response":"get"}
In this case I want to make a variable D13 with the value 1.
Thanks for any help.
Any examples, anything?
There are many implementations of JSON encoders/decoders. There’s probably one on your system already if you have certain plugins installed. It’s usually just a matter of accessing the module and calling its decode function.
local json = require "json" -- actual text depends on installed json module
local result = json.decode(json_string)
Going the other way is just as easy:
local json_string = json.encode(result)
The [tt]result[/tt] contains the decoded table structure of the given json string.
I’ll add a link to a module, but if you have dataMine installed, then it has one called [tt]json-dm[/tt].
[Edit : here’s one I wrote earlier: [url=http://forum.micasaverde.com/index.php/topic,17499.msg137677.html#msg137677]http://forum.micasaverde.com/index.php/topic,17499.msg137677.html#msg137677[/url] ]
