Have anyone tried to use an ethernet to serial adapter with Insteon. I was thinking of hooking up a 2412S to the adapter and use the IPSerial plugin in Vera. Have anyone tried this? Is this supported?
Thanks!
Bo
Thanks!
Bo
The 2412S version should be working with a serial to USB adapter. You can find more info about this on the link below, but if you already have everything you need, there’s no reason not to test this and see how it works.
