I have installed a 3-way light switch using a Intermatic CA3000 light switch and a regular non-zwave 3-way rocker and all works fine.
However, the non-zwave 3-way rocker is mounted in a 2 gang box next to another CA3000 and it does not match the dimpled rocker of the CA3000.
Does anyone know if it possible to wire two CA3000 together in a 3-way, or alternatively can I buy standard 3-way rocker light switches with dimpled rockers similar to the CA3000? Any other ideas for improving the aesthetics are welcome.
I do not think that you can use a CA3000 as a 3 way. You could use a CA5100 instead. This could be set up to run two scenes to control the light, one for on and the other for off.
I don’t own this device, but my guess would be no also. It’s also not shown in the instructions that way.
[...] or alternatively can I buy standard 3-way rocker light switches with dimpled rockers similar to the CA3000?
What is shown in the manual is a [i]CA-3PS[/i] as a matching switch; but they [url=http://forum.micasaverde.com/index.php/topic,10295.msg70884.html#msg70884]may be hard to find[/url]?
