I have done some digging on forums and read that using Blue Iris (if you get it working) will give you better frame rate.
I just added my first Camera (Foscam FI9821W V2) to my VeraLite. What a headache and I still don’t have pan and tilt working.
Now I plan on getting more cams. I might still get Blue Iris since its a very good Cam Management system over the vendor ones. But I might pick it up faster if its plays better with Vera!
I am using Foscam FI9805E outside.
I am using AutHomationHD and the Foscam Android app to view live streams of my camera. Great resolution and frame rate.
I am using BlueIris as my NVR recording on motion.
I tried to use the BlueIris as the source for Vera Streaming and it works but the picture frame rate is slower but it also depends what you chose as your server. JPGpush, etc (see screenshot)
@GLEBRON try my posting under
Foscam 8910W Manual Setup [How-to]
Which may help you with Pan and Tilt
I have developed a vera blue iris cam plugin with Snapshot and Streaming Support, PTZ and Motion sensor support
Download here
[url=https://github.com/undert03/vera-blueiris/]https://github.com/undert03/vera-blueiris/[/url]
Current Forum Thread
[url=http://forum.micasaverde.com/index.php/topic,25828.0.html]http://forum.micasaverde.com/index.php/topic,25828.0.html[/url]
