UserData::TempLogFileSystemFailure start 0
I’m seeing this error occur exactly every 6 minutes in the log. I have an RFXtrx transceiver attached to a Vera Plus. I doubt the transceiver is causing the error but no messages from the transceiver are being processed. The log has 15 errors near the start; one for each of my zwave devices. An example: ZWaveNode::GetVersionInfo node 2 device 5 doesn’t support Command class version. These errors occur immediately after ZWave::NightlyMaintenance
I have the latest firmware installed: 1.7.3501
If you’re seeing this:
UserData::WriteUserData saved–before move File Size: 174209 save size 174209 <0x76d46520>
02 01/29/18 7:41:39.444 UserData::TempLogFileSystemFailure start 0 <0x76d46520>
02 01/29/18 7:41:39.467 UserData::TempLogFileSystemFailure 5041 res:1
It’s not an error—it’s the user-data autosave, which occurs every 6 minutes. You can search the forum for more information.
