User name in openLuup and AltUI.
I have been trying to find a way to change the default username in AltUI under openLuup. Currently it is a string that I am assuming is generated by the openLuup software, how do I change this to match my required user name.
Please note that this is a stand alone install and has no Vera associated and the reason I want to change the username is to match the registered name in AltUI.
Which version are you using: the latest from the development branch, or the one from the master, or the last tagged release?
@akbooer
Here are the versions from the log: -
2016-04-26 06:41:45.826   openLuup.init::      version 2016.02.25  @akbooer
2016-04-26 06:41:45.839   openLuup.scheduler:: version 2016.03.01  @akbooer
2016-04-26 06:41:45.840   openLuup.wsapi::     version 2016.03.05  @akbooer
2016-04-26 06:41:45.840   openLuup.server::    version 2016.02.29  @akbooer
2016-04-26 06:41:45.842   openLuup.plugins::   version 2016.03.05  @akbooer
2016-04-26 06:41:45.845   openLuup.scenes::    version 2015.11.12  @akbooer
2016-04-26 06:41:45.847   openLuup.chdev::     version 2016.02.15  @akbooer
2016-04-26 06:41:45.848   openLuup.io:0:        version 2016.02.15  @akbooer
2016-04-26 06:41:45.848   openLuup.luup:0:      version 2016.03.01  @akbooer
2016-04-26 06:41:45.851   openLuup.rooms::     version 2015.10.15  @akbooer
2016-04-26 06:41:45.851   openLuup.requests::  version 2016.02.22  @akbooer
If you update to the latest development branch version and PM me your AltUI-registered user name then I can send you a key.
