Currently have a number of Linear WD500Z-1’s controlled by a VeraPlus and they all work fine.
My goal is to have one of the WD500z-1’s controlled when I switch another. To put names to them:
Dimmer 2 is in the Garage
Dimmer 1 in in my Foyer.
I would like the garage to go on / off when I manually switch the Foyer, but not when Vera switches the Foyer. I expect I will have to change the Foyer dimmer to a Cooper RF9540 or similar.
Question is, Can I create the control I want? Would I be using the Cooper instant status “signal” or is there another way to control them (like direct pairing / grouping or some such)?
I see a lot of information but can’t quite get the hang of these particular functions.
JohnRob
