My USB UIRT worked fine for months, but now does not respond to SendProntoCode anymore.
The led flashes when It detects an IR command sent from another remote (so it’s alive), and I get a “Message sent Successful” when sending a comand via Test Luup Code (Lua), but nothing happpens (no led confirmation, no error message, no reaction from the controlled device).
USB Uirt shows correctly under Add Remove devices tab.
As my projector spent 3 weeks at the technical assistance, I’m not sure if this issue started when I upgraded Vera to 1.1.1338 (and the Z-Wave chip as well) or more recently.
Any clue ? How can I perform a clean remove of USB Uirt so I can try to re-install it ?
Should I just add the code "luup.call_action( “urn:micasaverde-com:serviceId:HomeAutomationGateway1”, “Reload”, {}, 0 ) " under the tab Luup of the scene? I tried it but the scene will only work one time after every reboot. TIA
by me always there, the USB dirt is just worked for few minutes and then stop working!!
[quote=“alexlui, post:10, topic:169204”]Hi Ap15e,
Should I just add the code "luup.call_action( “urn:micasaverde-com:serviceId:HomeAutomationGateway1”, “Reload”, {}, 0 ) " under the tab Luup of the scene? I tried it but the scene will only work one time after every reboot. TIA[/quote]
