Hi As I use Imperihome, I want to use graphs, so I searched for a plugin for it.
So I found Datamine, but…wow that’s an old one. Should I still use datamine or it there an other plugin which can do the job?
As said I need it in combination with Imperihome and to store logs some longer time.
I tried datamine, but no matter what I try, the USB is not seen when I go to the configuration page.
I see in a shell that the Vera Edge has it under /dev/sda1
So I went to settings/logs and let Vera log to USB, that seems to work:
/dev/sda1 on /tmp/log/cmh type ext3 (rw,noatime,nodiratime,data=ordered)
And indeed I have data there.
So am I doing something wrong? Does datamine still work on Vera Edge UI7?
Thanks.
No one using data history?
Look at the dataMine’s debug page by clicking on the debug url. Search for this text:
Error reading tmpfile during mountcheck
If you see this, then you need to manually create the \dataMine directory. You do this on Vera with the stick unplugged. The \dataMine directory should not be on the stick. You can check the stick, in say a PC, to ensure it does not contain the \dataMine direectory.
More reading:
http://forum.micasaverde.com/index.php/topic,16243.msg205072/topicseen.html#msg205072
Note that MIOS had (at least on UI5) the nasty habit of formatting any stick it finds, when USB logging is enabled. This was known to create dataMine havoc and is not recommended.
If you can’t find the error string I described above then I have no solution for you. If you post the dataMine log and a screen capture of the dataMine tab then that might solicit more help.
