Dear all,
I’m a novice with vera lite and i need to add a USB Hub to connect a Current Coast Energy meter ( enviR) and a RFXCOM 433 USB and a FDTI cable to connect a PowerMax Plus .
I have tested several Hub’s but i can’t put the hub working.
Anybody have solution for this?
Thanks in advance
Vmoreira
Hello,
You should try using an USB hub that has a power supply too.
Are you using short usb cables ? Did you try connecting other usb devices ? Did they work ?
Posts in this forum that talk about USB hubs mention that you must use a powered USB hub. The hub must have its own power.
