USB drive
Tried yesterday to use an old 32Gb USB-stick which I don’t use anymore; Plugged into Vera Lite - didn’t recognize it.
So today I bought a new 16Gb stick; Nothing happens in UI5; It seems not to recognize this stick as well :frowning:
(Setup / Logs / “Store logs on USB device” cannot be checked; Unchecks immediately after I try)
Should I format the stick first ? Should it be partitioned to less than 16Gb first ?
Thanks for any advice,
Martin
Vera creates its own 500MB partition on the USB stick when you enable the Store logs on USB device option. It should not be necessary to pre-format the drive.
Vera is quite picky about USB sticks and it would not surprise me if it has issues with drives above a certain size. I use 4GB drives which work fine. My favourite is the SanDisk Fit which is tiny and inexpensive. See: SanDisk Fit 4GB.
Must be the size I guess, since it IS in fact a SanDisk Cruzer 16Gb.
May I should try to partition it to 4Gb; For the format should I use FAT16 or 32 ?
Thanks,
Martin
No. Don’t try to partition it. That kind of thing notoriously keeps Vera from accessing the drive. Vera needs an unmolested drive to work with.
Doesn’t work anyway - so I guess I’ll try; nothing to loose :wink:
It actually worked to partition it to 4Gb :slight_smile:
/Martin
You tried deleting all partitions? Vera needs a clean slate to work with. Vera makes it’s own partition. I myself have tried this with 2, 4, 16 and 32 GB drives. All but one (the one currently in Vera) have been corsair because that’s what I had on hand to tinker with. The 4 GB one currently in use is made by Sony I believe. If yours doesn’t work, for some mysterious reason, just go to walmart and pick up whatever they have for the lowest cost.
EDIT:
[quote=“flyveleder, post:6, topic:178786”]It actually worked to partition it to 4Gb :slight_smile:
/Martin[/quote]
Well color me amazed. What did Vera do with the drive? Did it whack your 4GB partition and repartition it to 500 MB? Has anyone else ever had this work? I most certainly have not.
Yes, it partitioned it to 500Mb.
However - I cannot be sure that it didn’t use the unpartitioned rest (12Gb) for it’s own partition, and left the 4Gb partition alone.
Thanks,
Martin
[quote=“flyveleder, post:1, topic:178786”]Tried yesterday to use an old 32Gb USB-stick which I don’t use anymore; Plugged into Vera Lite - didn’t recognize it.
(Setup / Logs / “Store logs on USB device” cannot be checked; Unchecks immediately after I try)[/quote]
You’re not going to believe the answer here… I just went through this nightmare!
Tried for days to get various 1GB USBs to work. Tried to check the box and it wouldn’t stick. Going crazy, cursing Vera and this half-baked product.
Guess what it was? I was using the latest Chrome as my browser, as soon as I used FireFox, I could check the box and everything worked.
QA on the Vera interface is none existent.
Hmmm…you could actually be correct. I am only using Google Chrome; All of the times I couldn’t check the box was from a PC running chrome.
Last time (where it finally worked) I was sitting in my couch with a Mac laptop - also chrome - and it worked.
I guess it could have been the browser all along - but I’m not sure :wink:
/Martin
It works OK for me using Chrome Version 31.0.1650.63 m.
I’m using Chrome Version 31.0.1650.63 m on Windows 7 SP1.
And Chrome is now telling me it needs to update…
Rex, what OS? Itcould be a OS specific version problem.
Just upgraded to Version 32.0.1700.72 m
And now the USB checkbox works.
So I take back what I said about Vera interface QA, it seems Chrome themselves introduced an anomaly on the Windows version.
[quote=“TC1, post:12, topic:178786”]I’m using Chrome Version 31.0.1650.63 m on Windows 7 SP1.
Rex, what OS? Itcould be a OS specific version problem.[/quote]
I’m running Win 7 Professional 6.1.7601 SP1 64 bit. Chrome still thinks it is up to date.
Yeah, running the same Win7 version here except Enterprise.
No idea why that one USB checkbox wouldn’t work with the previous version of Chrome, but it was maddening to say the least.
