its possible to Call and URL on some action???
- Door Open call URL
- Switch ON Call http://www.whaevert.com/xxx.php
Yes it is and you will find many examples if you try using the Search facility on this forum.
Have a look at this.
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events#Access_the_web
You put the necessary LUUP code into a scene.
sorry did not complete the question:
solution Using PLEG i mean.
Have the PLEG action run a scene that contains Lua that makes the http requiest.
Thank will do that.
