Urgent please guys!!!switch between lock and unlock in Vision lock
Hello guys
I have turned the handled to other side since my door opened in the opposite way the Door lock Zm1701 was designed for
Everything is working perfectly except that when i press lock it UNLOCKS and when i press UNLOCK it locks :frowning:
so if i enter the code it LOCKS :frowning:
Please help
Is there any parameter to be changed?
This exact question has been asked before on the forum. Why donโ€™t you try searching for it?
I tried searching but i wasnโ€™t luck
Today i found it the first post in the Lock, Motion & security section
I guess i was using the wrong search words
Thanx anyway
Tip: Search on Google, use site:forum.micasaverde.com. Itโ€™s much more forgiving of typos and synonyms.
For those finding this topic by search, here is the topic: http://forum.micasaverde.com/index.php?topic=14456.0
Hy Guys,
In internal PCB of 1701 have a small switch that invert the operation.
Turn the small switch and all will work!
