What Vera Product/Firmware are you on?
Obviously you could try updating to PLC 9.1 and PLEG 9.5 (the latest)
And see if that fixes your issues. I don’t remember there being any breaking changes between those versions but I have no idea if there is some kind of restriction based on what Vera production/version you are on. If worse come to worse.
Back up.
Install the updates for PLC/PLEG
See if it is fixed.
Else restore, and atleast you are no worse off then you are now.
Good point, guess I’ll give that a go. I’m on the latest Vera UI7 with my VeraPlus.
Update,
So I made a system backup, and tried to make PLEG backups but they were all empty even though all the data shows on the advanced tab for each variable.
I also noticed my registration status for PLEG is undefined. I assume that could be because it’s empty, since I’ve never had a problem with my registration since 2014 when I started using PLEG.
I’m updating now. Fingers crossed.
Update 2
No joy with an update, no joy with restoring saved PLEG backups. My most recent system backup is from just BEFORE I upgraded to the latest UI7. Seems I have to reset all to default to restore an earlier firmware?
I did a search with find in the OS, but didn’t see any files related to my PLEG devices (other than PLEG program files). Are there files for each individual PLEG device that I could pull from a backup and replace to see if I can jump start PLEG again? I’d like to avoid starting over if at all possible.
Update 3
Yay for Vera auto backups!! I’m going to try one of those from 2 days ago.
Update 4 I give up for today!
So I restored a backup from a few days ago, no joy. Read the instructions closely and tried a previous day, and ONE of the PLEG devices populated with data but the other 2 did not. I also found my Vera Alerts wasn’t working, but it did after the restore. I went ahead and restored to Sunday hoping I could get everything back and I’m back to square one. Vera Alerts doesn’t work, PLEG is all empty. Data is all present under Advanced > Variables. I even tried editing each variable and saving to no avail. I also closed the tab and switched browsers from Chrome to Firefox to make sure that wasn’t my problem.
Finally - I even tried restoring from PLEG backups, the files read, verify and say restored, but then even after a reboot and CTL+F5 they are still empty…
You said earlier I believe that it was showing as unlicensed. Did you restore your license?
Ok, new day, new discoveries:
I tried restoring the license yesterday to no avail. It seems more that the PLEG is just not reading its data.
Today I realized it’s not just PLEG being empty, ALL my plugins are dead! I have a multiswitch, can’t toggle switches, Vera Alerts doesn’t send alerts, Ping Sensor cannot arm or disarm, House Modes plugin cannot change modes.
It’s as if all my plugins are dead or they somehow fail to run? Could I have some corrupt flash or is there some underlying service that all plugins are depending on?
This seems unusual to me in the log but it’s been a long time since I have been in the logs…
x31 0x35 0x3a 0x35 0x38 0x3a 0x32 0x32 0x20 0x47 0x4d 0x54 0xd 0xa (Last-Modified: Fri, 11 Jun 2021 15:58:22 GMT\r\n) <0x710db520>
02 06/11/21 15:58:22.880 write_data_header wrote:0 bytes:46 <0x710db520>
02 06/11/21 15:58:22.881 write_data_header failed with 0/401 0x41 0x63 0x63 0x65 0x70 0x74 0x2d 0x52 0x61 0x6e 0x67 0x65 0x73 0x3a 0x20 0x62 0x79 0x74 0x65 0x73 0xd 0xa (Accept-Ranges: bytes\r\n) <0x710db520>
02 06/11/21 15:58:22.881 write_data_header wrote:0 bytes:22 <0x710db520>
02 06/11/21 15:58:22.882 write_data_header failed with 0/401 0x43 0x6f 0x6e 0x6e 0x65 0x63 0x74 0x69 0x6f 0x6e 0x3a 0x20 0x63 0x6c 0x6f 0x73 0x65 0xd 0xa (Connection: close\r\n) <0x710db520>
02 06/11/21 15:58:22.882 write_data_header wrote:0 bytes:19 <0x710db520>
02 06/11/21 15:58:22.883 write_data_header failed with 0/401 0x43 0x61 0x63 0x68 0x65 0x2d 0x43 0x6f 0x6e 0x74 0x72 0x6f 0x6c 0x3a 0x20 0x6e 0x6f 0x2d 0x63 0x61 0x63 0x68 0x65 0x2c 0x6e 0x6f 0x2d 0x73 0x74 0x6f 0x72 0x65 0xd 0xa (Cache-Control: no-cache,no-store\r\n) <0x710db520>
02 06/11/21 15:58:22.883 write_data_header wrote:0 bytes:34 <0x710db520>
02 06/11/21 15:58:22.884 write_data_header failed with 0/401 0x57 0x57 0x57 0x2d 0x41 0x75 0x74 0x68 0x65 0x6e 0x74 0x69 0x63 0x61 0x74 0x65 0x3a 0x20 0x42 0x61 0x73 0x69 0x63 0x20 0x72 0x65 0x61 0x6c 0x6d 0x3d 0x22 0x41 0x64 0x6d 0x69 0x6e 0x69 0x73 0x74 0x72 0x61 0x74 0x69 0x6f 0x6e 0x22 0xd 0xa (WWW-Authenticate: Basic realm="Administration"\r\n) <0x710db520>
02 06/11/21 15:58:22.884 write_data_header wrote:0 bytes:48 <0x710db520>
02 06/11/21 15:58:22.885 write_data_header failed with 0/401 0xd 0xa (\r\n) <0x710db520>
02 06/11/21 15:58:22.885 write_data_header wrote:0 bytes:2 <0x710db520>
02 06/11/21 15:58:22.892 Device_Basic::AddPoll 98 poll list full, deleting old one <0x70edb520>
06 06/11/21 15:58:22.893 Device_Variable::m_szValue_set device: 98 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x70edb520>
02 06/11/21 15:58:23.054 Device_Basic::AddPoll 108 poll list full, deleting old one <0x706db520>
06 06/11/21 15:58:23.056 Device_Variable::m_szValue_set device: 108 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x706db520>
02 06/11/21 15:58:23.140 Device_Basic::AddPoll 115 poll list full, deleting old one <0x70edb520>
06 06/11/21 15:58:23.141 Device_Variable::m_szValue_set device: 115 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x70edb520>
02 06/11/21 15:58:23.189 Device_Basic::AddPoll 132 poll list full, deleting old one <0x706db520>
06 06/11/21 15:58:23.191 Device_Variable::m_szValue_set device: 132 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 4.90 now: 4.90 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x706db520>
02 06/11/21 15:58:23.309 Device_Basic::AddPoll 109 poll list full, deleting old one <0x710db520>
06 06/11/21 15:58:23.311 Device_Variable::m_szValue_set device: 109 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x710db520>
02 06/11/21 15:58:23.412 Device_Basic::AddPoll 68 poll list full, deleting old one <0x708db520>
06 06/11/21 15:58:23.414 Device_Variable::m_szValue_set device: 68 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x708db520>
02 06/11/21 15:58:24.168 Device_Basic::AddPoll 54 poll list full, deleting old one <0x702db520>
06 06/11/21 15:58:24.169 Device_Variable::m_szValue_set device: 54 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x702db520>
02 06/11/21 15:58:30.251 JobHandler_LuaUPnP::REQ_Handler no handler for lr_PLCParameters <0x70edb520>
03 06/11/21 15:58:34.499 JobHandler_LuaUPnP::Reload: dr_reload Critical 1 m_bCriticalOnly 0 dirty data 1 running 1 <0x702db520>
02 06/11/21 15:58:34.934 UserData::CommitToDatabase data size 660194 660194 <0x702db520>
01 06/11/21 15:58:35.047 UserData::WriteUserData saved--before move File Size: 120331 save size 120331 <0x702db520>
02 06/11/21 15:58:35.047 UserData::TempLogFileSystemFailure start 0 <0x702db520>
02 06/11/21 15:58:35.066 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x702db520>
02 06/11/21 15:58:35.067 UserData::TempLogFileSystemFailure 699 res:1
-rw-r--r-- 1 root root 504 Jul 14 2011 /etc/cmh/user_data.json.luup.lzo
-rw-r--r-- 1 root root 119604 Jun 11 00:31 /etc/cmh/user_data.json.lzo
<0x702db520>
02 06/11/21 15:58:35.145 UserData::TempLogFileSystemFailure start 0 <0x702db520>
02 06/11/21 15:58:35.165 UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x702db520>
02 06/11/21 15:58:35.166 UserData::TempLogFileSystemFailure 610 res:1
-rw-r--r-- 1 root root 120331 Jun 11 15:58 /etc/cmh/user_data.json.lzo
<0x702db520>
06 06/11/21 15:58:35.167 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 2 #hooks: 0 upnp: 0 skip: 0 v:0x11c32b8/NONE duplicate:0 <0x702db520>
06 06/11/21 15:58:35.167 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: #1: Please wait! Getting the name now: Resetting ZWave Network #hooks: 0 upnp: 0 skip: 0 v:0x11d0e30/NONE duplicate:0 <0x702db520>
06 06/11/21 15:58:35.169 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 0 now: 3 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x702db520>
06 06/11/21 15:58:35.170 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusText was: OK now: GET_LANG(resetting_zigbee_network,Resetting Zigbee Network) #hooks: 0 upnp: 0 skip: 0 v:0x117b840/NONE duplicate:0 <0x702db520>
01 06/11/21 15:58:41.927 Main WatchDogRoutine: blocked - terminating 1 <0x708db520>
02 06/11/21 15:58:41.928 Dumping 31 locks <0x708db520>
02 06/11/21 15:58:41.929 finished check for exceptions <0x708db520>
02 06/11/21 15:58:41.934 finished check for exceptions <0x708db520>
02 06/11/21 15:58:41.934 OL: (0xc184fc) (>7284) ThreadedClass ../JobHandler/JobHandler.cpp l:432 time: 6:00:00p (1623445121 s) thread: 0x77380320 Rel: Y Got: Y <0x708db520>
02 06/11/21 15:58:41.934 OL: (0x1464f4c) (>7869) Lua LuaInterface.cpp l:2346 time: *****DL******12:31:50a (55611 s) thread: 0x769aa520 Rel: N Got: Y**RELEASING** <0x708db520>
02 06/11/21 15:58:41.935 finished check for exceptions <0x708db520>
02 06/11/21 15:58:41.935 OL: (0x1464f4c) (>7869) Lua LuaInterface.cpp l:2346 time: 12:31:50a (55611 s) thread: 0x769aa520 Rel: Y Got: Y <0x708db520>
02 06/11/21 15:58:41.935 OL: (0xc1bf84) (>2175254) alarm AlarmManager.cpp l:109 time: 3:58:36p (5 s) thread: 0x702db520 Rel: Y Got: Y <0x708db520>
2021-06-11 15:58:41 - LuaUPnP Terminated with Exit Code: 137
03 06/11/21 15:58:42.127 LuaUPNP: starting bLogUPnP 0 <0x77207320>
02 06/11/21 15:58:42.136 JobHandler_LuaUPnP::Run: pid 8820 didn't exit <0x77207320>
02 06/11/21 15:58:42.349 UserData::TempLogFileSystemFailure start 1 <0x77207320>
02 06/11/21 15:58:42.698 UserData::TempLogFileSystemFailure 9088 res:1
-rw-r--r-- 1 root root 54 Jun 11 00:31 /etc/cmh/zwave_version
df -h
Filesystem Size Used Available Use% Mounted on
rootfs 10.6M 1.1M 9.5M 11% /
/dev/root 8.0M 8.0M 0 100% /rom
tmpfs 124.3M 9.1M 115.3M 7% /tmp
/dev/mtdblock6 10.6M 1.1M 9.5M 11% /overlay
overlayfs:/overlay 10.6M 1.1M 9.5M 11% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock10 50.0M 12.3M 37.7M 25% /storage
/dev/mtdblock10 50.0M 12.3M 37.7M 25% /etc/cmh-firmware
/dev/mtdblock10 50.0M 12.3M 37.7M 25% /etc/cmh-backup
/dev/mtdblock9 9.8M 9.8M 0 100% /mios
/dev/mtdblock10 50.0M 12.3M 37.7M 25% /etc/cmh-ludl
/dev/mtdblock11 19.3M 1.5M 17.8M 8% /ezmi
/dev/mtdblock11 19.3M 1.5M 17.8M 8% /etc/cmh
logread
Fri Jun 11 15:56:01 2021 cron.info crond[2338]: crond: USER root pid 2467 cmd /usr/bin/Rotate_Logs.sh
Fri Jun 11 15:56:58 2021 authpriv.info dropbear[2645]: Child connection from LOCALLAN.194:62133
Fri Jun 11 15:57:01 2021 cron.info crond[2338]: crond: USER root pid 2646 cmd /usr/bin/Rotate_Logs.sh
Fri Jun 11 15:57:03 2021 authpriv.notice dropbear[2645]: Password auth succeeded for 'root' from LOCALLAN.194:62133
Fri Jun 11 15:57:03 2021 authpriv.info dropbear[2747]: Child connection from LOCALLAN.194:62134
Fri Jun 11 15:57:07 2021 authpriv.notice dropbear[2747]: Pubkey auth succeeded for 'root' with key
Fri Jun 11 15:58:01 2021 cron.info crond[2338]: crond: USER root pid 2863 cmd /usr/bin/Rotate_Logs.sh
Fri Jun 11 15:58:34 2021 user.notice set_led[3022]: START set_led.sh off zwave from /bin/sh -c /usr/bin/set_led.sh off zwave [3020] with parent /usr/bin/LuaUPnP [8820]
Fri Jun 11 15:58:34 2021 user.notice set_led[3040]: START set_led.sh off zigbee from /bin/sh -c /usr/bin/set_led.sh off zigbee [3039] with parent /usr/bin/LuaUPnP [8820]
Fri Jun 11 15:58:41 2021 user.err syslog: read error for port 3482: Connection reset by peer
dmesg
[ 32.380000] GMAC1_MAC_ADRL -- : 0xeff1a1cd
[ 32.388000] CDMA_CSG_CFG = 81000000
[ 32.396000] GDMA1_FWD_CFG = 20710000
[ 32.412000] device eth0.2 entered promiscuous mode
[ 32.420000] device eth0 entered promiscuous mode
[ 32.432000] br-wan: port 1(eth0.2) entered forwarding state
[ 32.444000] br-wan: port 1(eth0.2) entered forwarding state
[ 34.448000] br-wan: port 1(eth0.2) entered forwarding state
[ 35.476000] ESW: Link Status Changed - Port4 Link UP
[ 9855.636000] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
<0x77207320>
02 06/11/21 15:58:42.699 UserData::LoadUserData previous: 0 from *1.7.5186* <0x77207320>
09 06/11/21 15:58:42.700 UserData::ParseRooms 1 Living Room <0x77207320>
09 06/11/21 15:58:42.700 UserData::ParseRooms 2 Garage <0x77207320>
02 06/11/21 15:58:42.714 Device_Basic::m_sDescription_set device 54. description: Front Door exist already, new Description: Front Door 1 <0x77207320>
03 06/11/21 15:58:42.758 UserData::LoadUserData BuildVersion: *1.7.5186* (7.31) SvnVersion: *8371fac* Model: 36 Sercomm G450 flush: 0 changed: 0 resync: 9153 <0x77207320>
02 06/11/21 15:58:42.934 Device_LuaUPnP::CreateServices device 2 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:42.942 Device_LuaUPnP::CreateServices device 3 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:42.956 Device_LuaUPnP::CreateServices device 4 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:42.957 Device_LuaUPnP::CreateServices device 9 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:42.967 Device_LuaUPnP::CreateServices device 10 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:42.973 Device_LuaUPnP::CreateServices device 11 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:43.242 Device_LuaUPnP::CreateServices device 212 doesn't have interface, using topmost device interface <0x77207320>
02 06/11/21 15:58:43.278 Device_Basic::m_eConfigured_set device 1 was 0 now 0 startup <0x77207320>
02 06/11/21 15:58:43.279 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x77207320>
02 06/11/21 15:58:43.279 Device_Basic::m_eConfigured_set device 2 was 0 now -3 startup <0x77207320>
02 06/11/21 15:58:43.282 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x77207320>
02 06/11/21 15:58:43.283 Device_Basic::m_eConfigured_set device 3 was 0 now 0 startup <0x77207320>
02 06/11/21 15:58:43.286 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x77207320>
02 06/11/21 15:58:43.305 Device_Basic::m_eConfigured_set device 14 was 0 now 1 startup <0x77207320>
02 06/11/21 15:58:43.422 Device_Basic::m_eConfigured_set device 210 was 0 now 0 startup <0x77207320>
02 06/11/21 15:58:43.423 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x77207320>
02 06/11/21 15:58:43.423 Device_Basic::m_eConfigured_set device 211 was 0 now 0 startup <0x77207320>
02 06/11/21 15:58:43.424 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:ZWaveDevice1 <0x77207320>
02 06/11/21 15:58:43.424 Device_Basic::m_eConfigured_set device 212 was 0 now 0 startup <0x77207320>
02 06/11/21 15:58:43.483 UserData::ParseScenes2 invalid scene 54 button 3 device 129 or is upnp <0x77207320>
02 06/11/21 15:58:43.483 UserData::ParseScenes2 invalid scene 55 button 4 device 129 or is upnp <0x77207320>
02 06/11/21 15:58:43.485 UserData::ParseScenes2 invalid scene 57 button 6 device 129 or is upnp <0x77207320>
02 06/11/21 15:58:43.485 UserData::ParseScenes2 invalid scene 51 button 7 device 129 or is upnp <0x77207320>
06 06/11/21 15:58:43.572 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IODeviceXRef was: 195 now: 195 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77207320>
06 06/11/21 15:58:43.573 Device_Variable::m_szValue_set device: 18 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IOPortPath was: /dev/ttyUSB0 now: /dev/ttyUSB0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77207320>
02 06/11/21 15:58:43.574 ZWave::Start Z-Wave 500 series <0x77207320>
06 06/11/21 15:58:43.574 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastUpdate was: 1623389498 now: 1623445123 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77207320>
06 06/11/21 15:58:43.575 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 7 #hooks: 0 upnp: 0 skip: 0 v:0x16312b8/NONE duplicate:0 <0x77207320>
06 06/11/21 15:58:43.576 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: #1: Please wait! Getting the name now: Starting the Z-Wave network #hooks: 0 upnp: 0 skip: 0 v:0x163ee30/NONE duplicate:0 <0x77207320>
02 06/11/21 15:58:43.996 ZWaveJobHandler::Run connect to /dev/ttyS0 -0 lock 1 <0x76030520>
02 06/11/21 15:58:44.073 ZWaveJobHandler::Run connected to /dev/ttyS0=1 i=0 <0x76030520>
06 06/11/21 15:58:44.115 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 7 now: 7 #hooks: 0 upnp: 0 skip: 0 v:0x16312b8/NONE duplicate:1 <0x76030520>
06 06/11/21 15:58:44.115 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Starting the Z-Wave network now: Starting the Z-Wave network #hooks: 0 upnp: 0 skip: 0 v:0x163ee30/NONE duplicate:1 <0x76030520>
03 06/11/21 15:58:44.942 ZWJob_Initialize::JobDone version 6.1 type 1 role is 0 house id f12d25dc node id 93 suc 0 IsSecondary 0 bOnOtherNetwork 1 NodeIdServerPresent 0 IsRealPrimary 1 IsSuc 0 locale 1 fw_upgrade -1 <0x76030520>
06 06/11/21 15:58:44.946 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: VersionInfo was: 6.01 L:1 now: 6.01 L:1 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76030520>
06 06/11/21 15:58:44.946 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: HomeID was: House: 0xf12d25dc Node 5d Suc 0 now: House: 0xf12d25dc Node 5d Suc 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76030520>
06 06/11/21 15:58:44.947 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: Role was: Master SIS:NO PRI:YES now: Master SIS:NO PRI:YES #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76030520>
04 06/11/21 15:58:44.947 <Job ID="0" Name="init" Device="1" Created="2021-06-11 15:58:44" Started="2021-06-11 15:58:44" Completed="2021-06-11 15:58:44" Duration="0.369285000" Runtime="0.368677000" Status="Successful" LastNote=""/> <0x76030520>
02 06/11/21 15:58:45.179 ZWave::Start reset 0 use45:1 minor:1 model:36 port:/dev/ttyS0 nodes:34 using_prefer: 1 prefer 0.0 ports:/dev/ttyS0 - /dev/ttyS0 <0x77207320>
02 06/11/21 15:58:45.179 ZWave::Start can't use 4.5 <0x77207320>
06 06/11/21 15:58:45.180 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: ComPort was: /dev/ttyS2 now: /dev/ttyS2 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77207320>
06 06/11/21 15:58:45.180 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: LockComPort was: 1 now: 1 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x77207320>
06 06/11/21 15:58:45.181 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 0 now: 2 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x77207320>
06 06/11/21 15:58:45.181 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusText was: OK now: GET_LANG(init_zigbee,Starting Zigbee Network) #hooks: 0 upnp: 0 skip: 0 v:0x15e9848/NONE duplicate:0 <0x77207320>
02 06/11/21 15:58:46.342 ZWaveNode::UpdateCommandClasses node 1 empty -- -- <0x76030520>
09 06/11/21 15:58:46.343 ZWaveJobHandler::FindCustomDeviceType node 4/ has custom 2169 file D_DoorLock1.xml/ class desc Schlage Deadbolt clone 0 <0x76030520>
02 06/11/21 15:58:46.344 ZWaveNode::GetCustomZWaveNode bad node 4 class <0x76030520>
02 06/11/21 15:58:46.345 ZWaveNode::m_mapCommandClasses_Add setting m_bIsSecure for node 4 globalIgnoreSecurity: false <0x8bed15> <0x76030520>
02 06/11/21 15:58:46.345 ZWaveNode::m_mapCommandClasses_Add secure: true globalIgnoreSecurity: false <0x8bed15> <0x76030520>
09 06/11/21 15:58:46.348 ZWaveJobHandler::FindCustomDeviceType node 5/ has custom 2169 file D_DoorLock1.xml/ class desc Schlage Deadbolt clone 0 <0x76030520>
02 06/11/21 15:58:46.348 ZWaveNode::GetCustomZWaveNode bad node 5 class <0x76030520>
02 06/11/21 15:58:46.349 ZWaveNode::m_mapCommandClasses_Add setting m_bIsSecure for node 5 globalIgnoreSecurity: false <0x8bed15> <0x76030520>
02 06/11/21 15:58:46.349 ZWaveNode::m_mapCommandClasses_Add secure: true globalIgnoreSecurity: false <0x8bed15> <0x76030520> <0x76030520>
06 06/11/21 15:58:46.569 Device_Variable::m_szValue_set device: 196 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: 1 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0x13f3838/NONE duplicate:1 <0x76030520>
09 06/11/21 15:58:46.569 ZWaveJobHandler::FindCustomDeviceType node 95 had none <0x76030520>
02 06/11/21 15:58:46.570 Device_Basic::m_eConfigured_set device 197 was 1 now 1 zw initvalue <0x76030520>
06 06/11/21 15:58:46.570 Device_Variable::m_szValue_set device: 197 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: 1 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0x13f3838/NONE duplicate:1 <0x76030520>
02 06/11/21 15:58:46.570 Device_Basic::m_eConfigured_set device 197 was 1 now 1 zw configured <0x76030520>
06 06/11/21 15:58:46.571 Device_Variable::m_szValue_set device: 197 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: 1 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0x13f3838/NONE duplicate:1 <0x76030520>
09 06/11/21 15:58:46.571 ZWaveJobHandler::FindCustomDeviceType node 96 had none <0x76030520>
02 06/11/21 15:58:46.572 Device_Basic::m_eConfigured_set device 198 was 1 now 1 zw initvalue <0x76030520>
06 06/11/21 15:58:46.572 Device_Variable::m_szValue_set device: 198 service: urn:micasaverde-com:serviceId:HaDevice1 variable: Configured was: 1 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0x13f3838/NONE duplicate:1 <0x76030520>
02 06/11/21 15:58:46.572 Device_Basic::m_eConfigured_set device 198 was 1 now 1 zw configured <0x76030520>
09 06/11/21 15:58:46.573 ZWaveJobHandler::FindCustomDeviceType node 98/ has custom 7091 file D_MotionSensor1.xml/D_MotionSensorWithTamper1.json class desc 4-in-1 sensor clone 0 <0x76030520>
02 06/11/21 15:58:46.573 ZWaveNode::GetCustomZWaveNode bad node 98 class <0x76030520>
02 06/11/21 15:58:46.573 ZWaveNode::GetZWaveNode node 98 unknown generic 7 basic 4 specific 1 template D_MotionSensor1.xml <0x76030520>
02 06/11/21 15:58:46.574 ZWaveNode::m_mapCommandClasses_Add setting m_bIsSecure for node 98 globalIgnoreSecurity: false <0x8bed15> <0x76030520>
06 06/11/21 15:58:46.578 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:SceneController1 variable: Scenes was: now: #hooks: 0 upnp: 0 skip: 0 v:0x13f18f0/NONE duplicate:1 <0x76030520>
06 06/11/21 15:58:46.578 Device_Variable::m_szValue_set device: 129 service: urn:micasaverde-
09 06/11/21 15:58:46.579 ZWaveJobHandler::UpdateNodes node 1 dev 2 pnp 0 Device_NumTemplate D_SceneController1.xml type ZWaveController Room 0 auto-conf -1 cap 0x93 sec 0x96 res 0x0 bas 0x2 gen 0x2 spe 0x1 config -3 secure 0 _Scene Controller classes mfr: / mfr: 0x0 prodtype: 0x0 prodid: 0x0 notlistening: 0 list:1 rout:0 beam:1 rtsl:0 sec:0 1k:0 250:0 <0x76030520>
09 06/11/21 15:58:46.580 ZWaveJobHandler::UpdateNodes node 4 dev 3 pnp 2169 Device_NumTemplate D_DoorLock1.xml type ZWaveDoorlock Room 4 auto-conf 0 cap 0x53 sec 0xdc res 0x0 bas 0x4 gen 0x40 spe 0x3 config 0 secure 1 Patio Door classes 20-s,22,5d-s,62-s,63-s,70-s,71-s,72,7a,80-s,85-s,86,98, mfr: Schlage/BE469NX mfr: 0x3b prodtype: 0x6341 prodid: 0x5044 notlistening: 0 list:0 rout:1 beam:1 rtsl:1 sec:0 1k:1 250:0 <0x76030520>
09 06/11/21 15:58:46.581 ZWaveJobHandler::UpdateNodes node 11 dev 9 pnp 7531 Device_NumTemplate D_BinaryLight1.xml type ZWaveNonDimmableLight Room 5 auto-conf 0 cap 0xd3 sec 0x9c res 0x0 bas 0x4 gen 0x10 spe 0x1 config 0 secure 0 Porch Light classes 25,27,70,72,73,77,86, mfr: GE/Jasco/ZW4003 mfr: 0x63 prodtype: 0x5257 prodid: 0x3533 notlistening: 0 list:1 rout:1 beam:1 rtsl:1 sec:0 1k:0 250:0 <0x76030520>
02 06/11/21 15:58:46.582 ZWaveJobHandler::UpdateNodes not configuring node 12 because it's not listening <0x76030520>
09 06/11/21 15:58:46.582 ZWaveJobHandler::UpdateNodes node 12 dev 10 pnp 0 Device_NumTemplate D_MotionSensor1.xml type ZWaveBinarySensor Room 2 auto-conf 1 cap 0x53 sec 0x9c res 0x0 bas 0x4 gen 0x20 spe 0x1 config 1 secure 0 Garage Sensor classes 30,70,71,72,80,84,85,86, mfr: Ecolink/ mfr: 0x14a prodtype: 0x1 prodid: 0x3 notlistening: 1 list:0 rout:1 beam:1 rtsl:1 sec:0 1k:0 250:0 <0x76030520>
09 06/11/21 15:58:46.628 ZWaveJobHandler::UpdateNodes node 90 dev 180 pnp 0 Device_NumTemplate D_DimmableLight1.xml type ZWaveDimmableLight Room 6 auto-conf -1 cap 0xd2 sec 0x94 res 0x0 bas 0x3 gen 0x11 spe 0x1 config 1 secure 0 NightStand Lamp classes 26,27,70,72,73,75,86, mfr: ACT - Advanced Control Technologies/ mfr: 0x1 prodtype: 0x4450 prodid: 0x3030 notlistening: 0 list:1 rout:1 beam:1 rtsl:0 sec:0 1k:0 250:0 <0x76030520>
09 06/11/21 15:58:46.629 ZWaveJobHandler::UpdateNodes node 91 dev 183 pnp 0
09 06/11/21 15:58:46.640 ZWaveJobHandler::UpdateNodes node 98 dev 209 pnp 7091 Device_NumTemplate D_MotionSensor1.xml type ZWaveNode Room 6 auto-conf -1 cap 0x53 sec 0x9c res 0x1 bas 0x4 gen 0x7 spe 0x1 config 1 secure 1 MBR Sensor classes 31-s,59-s,5a-s,5e,70-s,71-s,72-s,73-s,7a-s,80-s,84-s,85-s,86-s,98, mfr: zooZ/ZSE40 mfr: 0x27a prodtype: 0x2021 prodid: 0x2101 notlistening: 1 list:0 rout:1 beam:1 rtsl:1 sec:0 1k:0 250:0 <0x76030520>
06 06/11/21 15:58:46.640 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 7 now: 5 #hooks: 0 upnp: 0 skip: 0 v:0x16312b8/NONE duplicate:0 <0x76030520>
06 06/11/21 15:58:46.641 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Starting the Z-Wave network now: Configuring Z-Wave devices in your system. #hooks: 0 upnp: 0 skip: 0 v:0x163ee30/NONE duplicate:0 <0x76030520>
04 06/11/21 15:58:46.654 <Job ID="1" Name="getnodes" Device="" Created="2021-06-11 15:58:45" Started="2021-06-11 15:58:45" Completed="2021-06-11 15:58:46" Duration="1.473460000" Runtime="1.473336000" Status="Successful" LastNote=""/> <0x76030520>
06 06/11/21 15:58:46.855 Device_Variable::m_szValue_set device: 205 service: urn:micasaverde-com:serviceId:GenericSensor1 variable: CurrentLevel was: 2656 now: 2656 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x76630520>
06 06/11/21 15:58:47.271 Device_Variable::m_szValue_set device: 189 service: urn:micasaverde-com:serviceId:ZigbeeNetwork1 variable: NetStatusID was: 2 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x75830520>
I put in a ticket with Vera support, we’ll see how that goes.
I had a similar problem a couple of years ago.
The registration appeared to have gone MIA and emails for support went unanswered.
The only solution apart from paying for another registration which I was reluctant to do as emails for support from RTS went unanswered was to rebuild the system with Reactor.
I still have PLEG running on another system using a VeraLite, it’s never missed a beat - that I put down to UI5
Have you tried a sytem restore from a known good point?
Well this whole issue was a lot simpler (and perhaps more complicated) than I thought.
After some digging and forum reading, I found this post:
Which led me to inspect my user_data.json and I ended up copying user_data.json.lzo.5 to user_data.json.lzo and rebooting. This going me (mostly) working again!!
Unfortunately, it didn’t take long (probably 1 luup reload) to go corrupt again. I’m having a lot of writedataheader errors in the log and so now I’m trying to clean up my storage before I try another backup of my user data json.
You are likely either out of space, or having failing memory in your device.
You said this was a Vera Plus with the latest firmware? If that is the case, it is likely not that the device is full, but that you are having some other worse type of failure. The later firmware’s addressed a lot of the space issues from earlier versions.
Support is a good next step.
