There are a number of discussions about the RFXtrx433 etc, but I was wondering if anyone had see or started work on something like this…
http://shop.ciseco.co.uk/urf-radio-module-and-serial-inteface-via-usb/
It seems lower cost and its based on the Texas Instruments CC1111 combined micro & RF transciever. Runs as standard at 868.3Mhz. The chip antenna is good for 868-915Mhz, will also work at 315Mhz and 433Mhz the range will be shorter
Hi
That looks perfect for my needs! I have been searching a lot for similar functionality.
I almost bought the RFXCOM433. But that frequency only supports 1/3 of my needs. I have an US version of the Powermax Pro (315Mhz), A german brand of the La Crosse Tech WS2810U-IT (868MHZ) and wanted to use multiple Oregon Scientific sensors (433MHz).
If someone could write the code for controlling this on a Vera2/3 would be more than fantastic! ;D
Best regards
Eddie
