Upgrading - Vera 3 UI5 - ZW 2.78 (Suc SIS:YES PRI:YES) to UI7 - ZW 3.83
Hi
I’m currently running UI5 with the ZW version set to 2.78, with the role “Suc SIS:YES PRI:YES”
This set up was required (and recommended by Vera) to improve the stability of my set up as I have a number of Danfoss Living Connect TRVs
Looking at the firmware details for the latest UI7. 7.10, it reports that it upgrades the ZW version to 3.83 - > http://support.getvera.com/customer/portal/articles/2078473
Has anyone successfully upgraded a UI5 Vera unit, running 2.78 with the role “Suc SIS:YES PRI:YES” to the latest Ui7 and ZW 3.83 ?
Is anyone aware of any issues with the Danfoss Living TRVs under UI7 / ZW 3.83
Hi
I upgraded my Vera3 to ui7 in november last year. Currently it is version 1.7.649 with zw 3.67 with SIS: NO PRI: YES. At no time it has been stable with 12 Danfoss LC. Some works fine, others done reply to commands. Al other devices and plugin works fine…
I also have a vera edge running zw 3.83 and latest firmware, with one thermostat. This thermostat does not work at all.
Stay with ui5 until all problems are sorted out.
Hi
a couple of days ago I downgraded my vera3 to 1.7.619 and after a couple of nights healing, everything seems to work fine.
@ moni,
do you recommend Vera3 UI5 upgrade to 1.7.619 rather than 1.7.649 ( latest F/W) ? I have some new Z-Wave devices ( with 500 series ) do not work on my Vera3 UI5, I want to upgrade to try soon.
@alexlui
Keep on using ui5 until ui7 i stable. I am using 1.7.619 and the Danfoss thermostats seemed stable, but they are not.
