I’m thinking about updating my Vera 1 to U14. I’m currently using firmware '979. Should I update to '996 first then proceed to U14 or just go directly from '979 to U14.
Thanks.
Thanks.
You should be able to directly update to UI4.
blazinace, I’m running 979 too, I’m waiting to upgrade, but I would be more than happy to take any lessons learned from you
I’m running Vera1 Version:1.0.995 and asked tech support for advice on the upgrade. The response was: “Anyway, the simple visit from the same network where Vera is to the page http://micasaverde.com/vera2 should perform the upgrade”
That didn’t work for me as it could not find my Vera. I wrote tech support back a week ago that I am using Vera 1 but have yet to hear back from them.
I searched the forums with no luck…
I set up an account at Mios but it still could not find my Vera to make the upgrade…Maybe it will work for you.
JOD.
Ps. Vera 1 users have become the step children so dont expect too much help!!
[quote=“JOD, post:4, topic:166477”]I’m running Vera1 Version:1.0.995 and asked tech support for advice on the upgrade. The response was: “Anyway, the simple visit from the same network where Vera is to the page http://micasaverde.com/vera2 should perform the upgrade”
JOD.
Ps. Vera 1 users have become the step children so dont expect too much help!![/quote]
JOD, did tech support help solve your problem ?
I am running 1.1.1047 (latest) and currently have some reboot issues related to this version. Others are having the same issues. Search “reboot” in the forum.
I suggest that you wait a couple of weeks when the new version arrives to fix this issue.
Thanks,
Darrell
I’ve made up my mind and I’m going to wait until a new version comes out. I’ve beem reading the forums and there are too many problems being reported.
@ blazinace,
The answer is No. However, I did figure it out on my own and have posted the same advice to other users. Try a different browser. I upgraded to UI4 1.1.1062 and it was really slow afterwards, I found several devices that had bug issues and I went back to UI2 .996
I purchased a Vera 2 UI4, did a backup from 996 and installed on Vera 2 and am now waiting for a FW upgrade to get that machine working.
It’s been my experience since 2008 that this has been a two steps forward and one step back scenario.
JOD.
FYI, I just installed UI2 996 from 979 with no problems so far. I did it for the SQ app and it’s working quite well. So well, that I will rarely ever use the web browser or smartphone web interface
I’ll stand by for UI4 but I don’t like a few things already like
[quote=“tt55du, post:9, topic:166477”]FYI, I just installed UI2 996 from 979 with no problems so far. I did it for the SQ app and it’s working quite well. So well, that I will rarely ever use the web browser or smartphone web interface
Thanks for the info. I’m beginning to change my mind. I’ll probably upgrade to '996 this weekend and see how it goes. My lights have been turning on by themselves at random times during the day. Tech support recommended that I upgrade to firmware U14.
Well, even with some issues which we’re sure we will fix soon, we still believe that UI4 is superior to UI2… I will try to see today what’s with some of the issues.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
