Upgraded to UI7 (from UI5), can't edit actions
Actually there are several things that don’t seem to work properly. I’m having UI7 buyer’s remorse.
I need to edit one of my actions, but the EDIT, TRIGGER NOW, and DELETE buttons are greyed out. The press, but nothing happens.
I’ve cleared my cache - even logging in incognito mode.
Also, when I try to open the ‘status’ window by clicking status on the control page, it opens, but it’s blank.
Hoping this is an easy fix…
Edit to add: When I click on conditions under the PLEG device I get this:
Just wanted to add that I ran the individual update request URLs, receiving OK each time, waiting for reload to complete, and doing them in order as specified here.
I then restarted VERA, closed all my browsers, and tried again. Still no go.
What else is there that I can do?
As usual, a little digging got me my answer. To anyone else wet enough behind the ears to be stymied like this - the missing step was POWER CYCLING Vera. I was hitting the ‘reload luup’ button under settings - and that clearly wasn’t doing the trick.
