So, I have not been around for a long time. My Vera has been running fine.
My Vera has V 1.0.616 installed and has been running without much issue. When I go to the download section it does not give notification of any firmware upgrade being available.
I noticed that there is UI2 and UI3 firmware upgrade options mentioned here. Should I install UI2 1.0.994?
Any gotchas like lost settings doing this upgrade? I figure I’ll need to do this upgrade before moving to UI4 eventually. (As I doubt UI1 directly to → UI4 will be a viable upgrade path.)
Comments? Advice?
Thanks.
