There are differences between Vera Plus and Vera Lite, that would improve the communication you already have. Starting with the technical specs (Hardware CPU: 880MHz MIPS SoC Flash Memory: NAND 128MB Memory: DDR3 256MB) up to the fact that it adds the Zigbee protocol the new controller should work for you.
I hope this helps,[/quote]
Ok, but i don t need zigbee.
Just want to know if the system will be quickier with my aeotec switches and dimmers.
Or it will be the same thing , and better cpu and RAM will only take effect if i have too mane switches, dimmers, sensors etc… ?
Or it will be the same thing , and better cpu and RAM will only take effect if i have too mane switches, dimmers, sensors etc… ?[/quote]
Hello,
The Z-wave chips and firmware on the two are also different, however, I won’t affirm the Z-wave communication speed will be faster since this largely depends on the environment and the range of the devices.
