I’m trying to update the firmware on my Vera Lite. When I go to getvera.com > Support > Update Firmware and go through the wizard, I select my device and it says " No (or non-valid) device selected. go back and select a valid device".
I also cannot do this from the local UI. It says “You are running the latest version: 1.6.641” even though I know UI7 has been out for some time and I am not on it.
I can access my Vera remotely through the app, so I’m not sure why it can’t find it. Can anyone provide some insight? Thanks!!
[quote=“jasonkhonlaw, post:1, topic:187343”]I’m trying to update the firmware on my Vera Lite. When I go to getvera.com > Support > Update Firmware and go through the wizard, I select my device and it says " No (or non-valid) device selected. go back and select a valid device".
I can access my Vera remotely through the app, so I’m not sure why it can’t find it. Can anyone provide some insight? Thanks!![/quote]
Are you on the older UI6 or UI5? I would do a support ticket with Vera and have them do it.
