Updating Progam Logic Plugins
You shouldn’t loose your settings on update.
  • Garrett
Thanks Garrett. Do I just go into apps, uninstall PLEG and then re-install v5.8? That’ll keep the PLEGs the the v5.7 app already created?
You do not need to remove anything to update the plugins. Please see this thread:
http://forum.micasaverde.com/index.php/topic,14446.0.html
  • Garrett
Thanks Garrett, worked perfectly. I missed that when I was looking at the thread too quickly.
[quote=“RichardTSchaefer, post:1, topic:175015”]Open your Vera control panel in a browser window. You can monitor the status of Vera reloading from here.
Open up a separate browser window. With this window issue each of the following commands … waiting for Vera to reload before issuing a subsequent command.
The response from each command will be an OK
Refresh the contents of the Vera Control Panel, before using it.
[hr]
To Update Program Logic Timer Switch
http://YourVeraIP:3480/data_request?id=update_plugin&Plugin=3018
To Update Program Logic Event Generator
http://YourVeraIP:3480/data_request?id=update_plugin&Plugin=3066
To Update Program Logic Core
http://YourVeraIP:3480/data_request?id=update_plugin&Plugin=3086
[hr]
This can also be done remotely by using the form:
https://VeraFwdAddress/VeraUserName/VeraPassword/VeraID/data_request?id=update_plugin&Plugin=[b]XXX[/b]
Where:
[ul][li]VeraFwdAddress - can be found by issuing the web request:
http://sta1.mios.com/locator_json.php?username=[b]YourVeraUserName[/b][/li]
[li]VeraUserName is your username at cp.mios.com[/li]
[li]VeraPassword is your password at cp.mios.com[/li]
[li]VeraID is your Vera ID, also available from the request a few lines up.[/li][/ul][/quote]
Do you know if this update information holds true to UI6 for both local update and remote?
Update: I’m running UI6. I enabled Auto Update on the app and they updated automatically. I did not try the link commands. Thanks!
@garrettwp, you know you just linked to this thread, right?
@aaronsquire
The remote update will NOT work with UI6.
I’m trying to update to the latest PLEG but the manual update is simply returning: BAD_PLUGIN
Nothing is seen in the status section of my vera in the other window. I’m on a pretty old version as I failed to keep an eye on updates. I’m on 5.2.
The only thing I can think of is to uninstall the plugins and start over. I would rather not loose all of the settings as there are ALOT.
Side note, I just read about the new license system. Mine never stopped working and I have several PLEG’s with way more than 5 each.
Thanks Richard! Your plugin is well worth the licensing fee. I look forward to the new features I have been missing!
looks like I have a new issue, when I open a PLEG, I have this message. I guess that autoupdate weas on but causes issues, can I have some guidance on how to fix the problem ?
Follow the instructions in the first post to update the pleg plugin.
  • Garrett
I am having a problem with version mismatch on my Vera3. I do have the apps set to auto update.
PLC is version 7.31 and PLEG is 7.33
I have tried doing the manual update as described in this thread without any luck.
Any ideas on what I may be missing?
today is not a good day…
http://forum.micasaverde.com/index.php/topic,17624.msg214566.html#msg214566
Hi Richard
In UI7 the Icon does not show
I looked ande the shortcut (.png) looks missing in the: (image)
When you upgrade (or downgrade) from UI5 to UI7 you need to update the Plugins.
i did a reinstall without help
i am not able to access my unit in any way now so i have to check if an update is available later
Hi Richard
I did a full un- and re-inistall of pleg and enabled automatic updates, which already was.
I checked the PLEG device but no icon (The app itself has an icon though)
I opened WINSCP and noticed in the “/cmh/skins/default/img/devices/device_states/” folder the link “ProgramLogicEG.png” missing (which is actual a link but you’ll know that)
I then edited the link in winscp to change the link to “/etc/cmh-ludl/ProgramLogicEG.png” (I noticed the actial icon in there like the others)
Now I have an icon on my PLEG device
Is it possible the installation (through the apps in the Vera UI7) has a minor bug and does not create the link?
Script that creates the link has not changed in many months … and the link creation is the first of 12 links that are created.
Don’t know why this is happening then
Hi Richard
I found this message, so more having the same issue, sometimes(!)
http://forum.micasaverde.com/index.php/topic,30808.msg224044.html#msg224044
Richard,
I was in the process of opening my change purse to buy another PLEG License but am unable to.
I open one of my PLEG device(s) => Register and receive the following msg “[glow=red,2,300]Error executing function plc_Register(): PLC.RegisterMsg is undefined[/glow]”. Any suggestions, Mike
