1. Device Settings page
Go to Settings → Devices.
You will have access to the list of your devices.
List contains items (rounded boxes) which has these information:
Device Name
Controller ID
Controller Status
Device Details Info button
Function button to display and edit all settings on the device
All looking nice but I can’t edit a saved scene/meshbot. While trying to test any of the new “time” options I can’t update any created scene. Once I click “edit” I end up with a blank screen and flashing/spinning wheel.
It seems to work “fine” if I don’t use the special/custom time function.
Meshbots created a couple of days ago with the time function can be edited today. However the part in below screen shot realy behaves strange while editing. The start and end time fields seem to "interact in a strange way. Changing the hours in the end time also changes the am/pm field in the start time? and there is more like this when playing with this function.
First please set an automatic redirect to https for this site. You ask for credentials and doing that on plain http is simple not done for the last decade.
Next it still does not work for me. When logging on with my main account that has Versa and one atom just gives a blank page. My account with and atom and a H2 give the main screen and a button to sign in again ?!?!. When I enter the same credentials in that i get an invalid uid/pwd message.
It took weeks to get my uid to work with an earlier release. Now it is broke again.
I get a total blank (white) page. I guess it has something to do with my relativly old hub but at least some message would be much better - just to know what is going on.
We will add automatic redirect from http to https. Our DevOps have this task in their scope.
As I know, we are building Ezlogic using only new cloud. It means, we can interact with following types of hubs: Atom, Plughub, Watervalve (we are launching it), E450 (Ezlo Plus), E550 (Ezlo Secure). I will discuss compatibility with other types. But, I agree, we must not have a blank page in any case.
We will fix this “blank page” issue. Also, could you please provide any info about your hub?
As I said - relativly old hub - so it’s Vera. Also as I said - a simple message when it detects incompatible hub would be nice so we won’t be wondering what is going on. Thanks for the info.
i see,
for now this only supports Ezlo hubs.
We are thinking about building a Vera to Ezlo Bridge so that you can use ezlogic with old Vera hubs…(but early stages).
