Done… here is the log.
PLTS is Device 49
Humidity sensor is combined 4in1 device #41
I am surprised to see arm and bypass evaluations as for device 49 there is only a trigger condition with SdBHum<60. The device is armed all the time.
06 05/26/13 11:06:54.739 Device_Variable::m_szValue_set device: 41 service: urn:micasaverde-com:serviceId:HumiditySensor1 variable: CurrentLevel was: 55 now: 56 #hooks: 3 upnp: 0 v:0xf75e70/NONE duplicate:0 <0x2bc15680>
06 05/26/13 11:06:54.740 Device_Variable::m_szValue_set device: 19 service: urn:futzle-com:serviceId:CombinationSwitch1 variable: Label was: 1/2 now: 1/2 #hooks: 0 upnp: 0 v:0xeadfc8/NONE duplicate:1 <0x2bc15680>
06 05/26/13 11:06:54.740 Device_Variable::m_szValue_set device: 19 service: urn:futzle-com:serviceId:CombinationSwitch1 variable: Status was: 0 now: 0 #hooks: 1 upnp: 0 v:0xead398/NONE duplicate:1 <0x2bc15680>
06 05/26/13 11:06:54.741 Device_Variable::m_szValue_set device: 19 service: urn:upnp-org:serviceId:SwitchPower1 variable: Status was: 0 now: 0 #hooks: 1 upnp: 0 v:0xe716a8/NONE duplicate:1 <0x2bc15680>
06 05/26/13 11:06:54.745 Device_Variable::m_szValue_set device: 48 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ObjectStatusMap was: {{name ='Arm', state = nil, seq = 1369499887},{name ='Bypass', state = false, seq = 1369553421},{name ='Reset', state = nil, seq = 0},{name ='Trigger', state = false, seq = 1369541930},{name ='Trigger2', state = nil, seq = 0},{name ='Restart', state = nil, seq = 0},{name ='Restart2', state = nil, seq = 0},{name ='On', state = nil, seq = 0},{name ='Off', state = nil, seq = 0},{name ='ExtHum_Sup65', state = false, seq = 1369553421},{name ='ExtHum_inf63', state = true, seq = 1369559050},{name ='SdBHum', state = '55', seq = 1369555613},} now: {{name ='Arm', state = nil, seq = 1369499887},{name ='Bypass', state = false, seq = 1369553421},{name ='Reset', state = nil, seq = 0},{name ='Trigger', state = false, seq = 1369541930},{name ='Trigger2', state = nil, seq = 0},{name ='Restart', state = nil, seq = 0},{name ='Restart2', state = nil, seq = 0},{name ='On', state = nil, seq = 0},{name ='Off', state = nil, seq = 0},{name ='ExtHum_Sup65', state = false, seq = 1369553421},{name ='ExtHum_inf63', state = true, seq = 1369559050},{name ='SdBHum', state = '56', seq = 1369559214},} #hooks: 0 upnp: 0 v:0xfb83a0/NONE duplicate:0 <0x2bc15680>
50 05/26/13 11:06:54.746 luup_log:49: PLTS:49:PropertyUpdate:SdBHum: from:55 to:56 <0x2bc15680>
50 05/26/13 11:06:54.747 luup_log:49: PLTS:49:EvalConditions:Condition:Arm Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:06:54.747 luup_log:49: PLTS:49:EvalConditions:Condition:Bypass Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:06:54.748 luup_log:49: PLTS:49:EvalConditions:Condition:Reset Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:06:54.749 luup_log:49: PLTS:49:EvalConditions:Condition:Trigger Trigger:SdBHum Result:true <0x2bc15680>
50 05/26/13 11:06:54.750 luup_log:49: PLTS:49:TriggerCondition:Trigger <0x2bc15680>
50 05/26/13 11:06:54.750 luup_log:49: PLTS:49:Interval:5:1 <0x2bc15680>
50 05/26/13 11:06:54.751 luup_log:49: PLTS:49:SetState:From:0 To:3 Via:1 <0x2bc15680>
50 05/26/13 11:06:54.751 luup_log:49: PLTS:49:StateTriggerAction: <0x2bc15680>
50 05/26/13 11:06:54.751 luup_log:49: PLTS:49:FireAction:Nothing found for:Trigger <0x2bc15680>
06 05/26/13 11:06:54.752 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: ToggleTime was: 1369555618 now: 1369559219 #hooks: 0 upnp: 0 v:0xf94560/NONE duplicate:0 <0x2bc15680>
50 05/26/13 11:06:54.753 luup_log:49: PLTS:49:StateToggleAction: <0x2bc15680>
50 05/26/13 11:06:54.753 luup_log:49: PLTS:49:FireAction:On <0x2bc15680>
08 05/26/13 11:06:54.754 JobHandler_LuaUPnP::HandleActionRequest device: 16 service: urn:upnp-org:serviceId:IOSPush1 action: SendProwlNotification <0x2bc15680>
08 05/26/13 11:06:54.754 JobHandler_LuaUPnP::HandleActionRequest argument Description= <0x2bc15680>
08 05/26/13 11:06:54.754 JobHandler_LuaUPnP::HandleActionRequest argument Priority= <0x2bc15680>
08 05/26/13 11:06:54.754 JobHandler_LuaUPnP::HandleActionRequest argument Event=PLTS VMC tripped - PV <0x2bc15680>
08 05/26/13 11:06:54.755 JobHandler_LuaUPnP::HandleActionRequest argument URL= <0x2bc15680>
06 05/26/13 11:06:56.072 Device_Variable::m_szValue_set device: 16 service: urn:upnp-org:serviceId:IOSPush1 variable: TimeSend was: 1369555614 now: 1369559216 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 __LEAK__ this:16384 start:2629632 to 0x1472000 <0x2bc15680>
06 05/26/13 11:06:56.073 Device_Variable::m_szValue_set device: 16 service: urn:upnp-org:serviceId:IOSPush1 variable: ProwlCount was: 502 now: 503 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bc15680>
06 05/26/13 11:06:56.074 Device_Variable::m_szValue_set device: 16 service: urn:upnp-org:serviceId:IOSPush1 variable: LastError was: RST - 10:42 now: Ok - 11:06 - (Prowl) #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bc15680>
06 05/26/13 11:07:01.292 Device_Variable::m_szValue_set device: 16 service: urn:upnp-org:serviceId:IOSPush1 variable: ProwlRemaining was: 998 now: 999 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 __LEAK__ this:32768 start:2662400 to 0x147a000 <0x2bc15680>
06 05/26/13 11:07:01.308 Device_Variable::m_szValue_set device: 16 service: urn:upnp-org:serviceId:IOSPush1 variable: ProwlResetDate was: 1369557774 now: 1369562814 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bc15680>
06 05/26/13 11:07:01.309 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: Status was: 0 now: 1 #hooks: 0 upnp: 0 v:0xf9d7b0/NONE duplicate:0 <0x2bc15680>
06 05/26/13 11:07:01.310 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: State was: 0 now: 3 #hooks: 0 upnp: 0 v:0xf9d790/NONE duplicate:0 <0x2bc15680>
06 05/26/13 11:07:01.311 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: LastStateChange was: 1369555618 now: 1369559221 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bc15680>
50 05/26/13 11:07:01.311 luup_log:49: PLTS:49:EvalConditions:Condition:Trigger2 Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:07:01.312 luup_log:49: PLTS:49:EvalConditions:Condition:Restart Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:07:01.313 luup_log:49: PLTS:49:EvalConditions:Condition:Restart2 Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:07:01.313 luup_log:49: PLTS:49:EvalConditions:Condition:On Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:07:01.314 luup_log:49: PLTS:49:EvalConditions:Condition:Off Trigger:SdBHum Result:false <0x2bc15680>
50 05/26/13 11:07:01.315 luup_log:49: PLTS:49:SaveDB:{{name ='Arm', state = nil, seq = 0},{name ='Bypass', state = nil, seq = 0},{name ='Reset', state = nil, seq = 0},{name ='Trigger', state = true, seq = 1369559221},{name ='Trigger2', state = nil, seq = 0},{name ='Restart', state = nil, seq = 0},{name ='Restart2', state = nil, seq = 0},{name ='On', state = nil, seq = 0},{name ='Off', state = nil, seq = 0},{name ='SdBHum', state = '56', seq = 1369559214},} <0x2bc15680>
06 05/26/13 11:07:01.315 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicC variable: ObjectStatusMap was: {{name ='Arm', state = nil, seq = 0},{name ='Bypass', state = nil, seq = 0},{name ='Reset', state = nil, seq = 0},{name ='Trigger', state = true, seq = 1369555614},{name ='Trigger2', state = nil, seq = 0},{name ='Restart', state = nil, seq = 0},{name ='Restart2', state = nil, seq = 0},{name ='On', state = nil, seq = 0},{name ='Off', state = nil, seq = 0},{name ='SdBHum', state = '55', seq = 1369555613},} now: {{name ='Arm', state = nil, seq = 0},{name ='Bypass', state = nil, seq = 0},{name ='Reset', state = nil, seq = 0},{name ='Trigger', state = true, seq = 1369559221},{name ='Trigger2', state = nil, seq = 0},{name ='Restart', state = nil, seq = 0},{name ='Restart2', state = nil, seq = 0},{name ='On', state = nil, seq = 0},{name ='Off', state = nil, seq = 0},{name ='SdBHum', state = '56', seq = 1369559214},} #hooks: 0 upnp: 0 v:0xfb83a0/NONE duplicate:0 <0x2bc15680>
02 05/26/13 11:07:01.317 ZW_Send_Data node 8 NO ROUTE (nil) <0x2be15680>
02 05/26/13 11:07:01.318 LOG_CHECK_MEMORY_LEAK pMem start 0x1437000 now 0x147a000 last 0x146e000 leaked 274432 <0x2bc15680>
50 05/26/13 11:07:01.321 luup_log:49: PLTS:49:SetState:From:3 To:0 Via:0 <0x2da15680>
50 05/26/13 11:07:01.321 luup_log:49: PLTS:49:StateResetAction: <0x2da15680>
50 05/26/13 11:07:01.322 luup_log:49: PLTS:49:FireAction:Nothing found for:Reset <0x2da15680>
50 05/26/13 11:07:01.323 luup_log:49: PLTS:49:FireAction:Nothing found for:Off <0x2da15680>
06 05/26/13 11:07:01.323 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: Status was: 1 now: 0 #hooks: 0 upnp: 0 v:0xf9d7b0/NONE duplicate:0 <0x2da15680>
06 05/26/13 11:07:01.324 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: State was: 3 now: 0 #hooks: 0 upnp: 0 v:0xf9d790/NONE duplicate:0 <0x2da15680>
06 05/26/13 11:07:01.324 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: LastStateChange was: 1369559221 now: 1369559221 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2da15680>
06 05/26/13 11:07:01.325 Device_Variable::m_szValue_set device: 49 service: urn:rts-services-com:serviceId:ProgramLogicTS variable: TimeRemaining was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2da15680>
50 05/26/13 11:07:08.611 luup_log:25: RFXtrx: Received message: 08 50 02 01 E0 01 00 D9 59 <0x2f6a5680>
06 05/26/13 11:07:08.611 Device_Variable::m_szValue_set device: 25 service: urn:rfxcom-com:serviceId:rfxtrx1 variable: LastReceivedMsg was: 0A 52 02 01 8C 05 00 C4 36 00 69 now: 08 50 02 01 E0 01 00 D9 59 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2f6a5680>
50 05/26/13 11:07:08.613 luup_log:25: RFXtrx: cmds: T2/57345 Temperature 21.7 T2/57345 BatteryLevel 100 <0x2f6a5680>
06 05/26/13 11:07:08.615 Device_Variable::m_szValue_set device: 33 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 21.7 now: 21.7 #hooks: 0 upnp: 0 v:0xf57c08/NONE duplicate:1 <0x2f6a5680>
06 05/26/13 11:07:08.615 Device_Variable::m_szValue_set device: 33 service: urn:micasaverde-com:serviceId:HaDevice1 variable: BatteryDate was: 1369559189 now: 1369559228 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2f6a5680>
06 05/26/13 11:07:08.616 Device_Variable::m_szValue_set device: 33 service: urn:micasaverde-com:serviceId:HaDevice1 variable: BatteryLevel was: 100 now: 100 #hooks: 0 upnp: 0 v:0xe66f40/NONE duplicate:1 <0x2f6a5680>
06 05/26/13 11:07:15.133 Device_Variable::m_szValue_set device: 46 service: urn:demo-ted-striker:serviceId:PingSensor1 variable: CurrentFailureCount was: 0 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2d615680>
02 05/26/13 11:07:17.179 ZWaveSerial::GetFrame 0x2be14f58 timed out now 0 m_listGetFramePending 0 <0x2be15680>
02 05/26/13 11:07:17.179 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x2be15680>
01 05/26/13 11:07:17.180 ZWJob_PollNode::Run job job#56 :pollnode_wake #8 dev:38 (0x1451588) N:8 P:20 S:1 ZW_Send_Data to node 8 failed 1 req 0x14701d8/1 abort m_iFrameID 0 <0x2be15680>
02 05/26/13 11:07:17.180 ZWJob_PollNode::PollFailed job job#56 :pollnode_wake #8 dev:38 (0x1451588) N:8 P:20 S:1 node 8 battery 1 <0x2be15680>
04 05/26/13 11:07:17.181 <0x2be15680>
I hope you can deduce from this what is the problem…
[EDIT] Moreover my other PLTS is firing actions in Bypass mode… totally strange ! Are U sure I don’t need to reinstall PL plugin ?
