parkerc
February 6, 2013, 12:03pm
1
Hi
I’ve just relocated a battery device to another location in the house and to inform Vera I clicked on the Update Neighbor Nodes button under the Device Options tab.
Now my understanding of this button is that it does a ‘mini Heal’ process whereby it looks at the nodes and routes available in the mesh for that device and then updates the device with neigbor Nodes.
As the device was installed near Vera, it was intially populated with a number of Nodes in the neighbor listing “1, 6, 10, 15, 16” - so moving it to it’s new location, and clicking Update Neighbor Nodes I assumed these would change. However looking in the logs, it seems to do absolutely nothing (well that’s what I assume it is saying) - as the original list of neigbor nodes remains the same…
08 02/06/13 11:40:27.830 JobHandler_LuaUPnP::HandleActionRequest device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 action: e[36;1mUpdateNeighborse[0m <0x2fd9a680>
08 02/06/13 11:40:27.831 JobHandler_LuaUPnP::HandleActionRequest argument Device=134 <0x2fd9a680>
03 02/06/13 11:40:27.831 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x2fd9a680>
06 02/06/13 11:40:27.831 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mLastHeale[0m was: 1360149845 now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2fd9a680>
06 02/06/13 11:40:27.861 Device_Variable::m_szValue_set device: 134 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mNeighborsInversee[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2fd9a680>
06 02/06/13 11:40:27.861 Device_Variable::m_szValue_set device: 134 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mHealthe[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2fd9a680>
02 02/06/13 11:40:27.862 e[33;1mZWJob_HealNetwork::ZWJob_HealNetwork node 17/0xeecf30 of 1 TO3066: 0 20/0xeecf30/1 nummin:0 numcycle:0 conf:0 mr:1 only 0 neighb: 0 stage 4 to 0 retry 0 job#38 :heal node (0x1a33e10) P:50 S:0e[0m <0x2fd9a680>
02 02/06/13 11:40:27.867 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.868 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX1 # of hops 0e[0m <0x2b959680>
02 02/06/13 11:40:27.868 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX6 tested 0 test cases 0 mr 0e[0m <0x2b959680>
02 02/06/13 11:40:27.868 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 3 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.869 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 4 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.869 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 6 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.869 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 9 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.870 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 10 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.879 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 11 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.880 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 12 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.880 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 13 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.880 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 14 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.880 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 15 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.881 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 16 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.881 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 17 no routese[0m <0x2b959680>
02 02/06/13 11:40:27.882 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.882 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.884 e[33;1mZZZ m_pZWJob_Base_Current_assign (nil)e[0m <0x2b959680>
02 02/06/13 11:40:27.884 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX3e[0m <0x2b959680>
02 02/06/13 11:40:27.885 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.885 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.887 e[33;1mZZZ m_pZWJob_Base_Current_assign (nil)e[0m <0x2b959680>
02 02/06/13 11:40:27.888 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX3e[0m <0x2b959680>
02 02/06/13 11:40:27.888 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.888 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX1e[0m <0x2b959680>
02 02/06/13 11:40:27.889 e[33;1mZWJob_HealNetwork::DumpResult XXX3e[0m <0x2b959680>
02 02/06/13 11:40:28.168 e[33;1mZWJob_HealNetwork::LogJob 2974698/OK:2974698 e[0m <0x2b959680>
02 02/06/13 11:40:28.170 e[33;1mZWJob_HealNetwork::DumpResult m_mapHealNetworkStressTest=0e[0m <0x2b959680>
06 02/06/13 11:40:28.296 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mLastHeale[0m was: now: 1360150828 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b959680>
04 02/06/13 11:40:28.298 <0x2b959680>
03 02/06/13 11:40:28.299 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 0 <0x2b959680>
02 02/06/13 11:40:28.299 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX2e[0m <0x2b959680>
I should add that while most of my nodes are battery powered, 4 are mains powered and should act as a routing nodes.
I appreciate I can do a system heal which would target nodes multiple time - but seeing that the button is there and quite promanant on one of the tab - it’s a logical option to choose after moving just one device - therefore I’m cusrious does the button work for others ?
parkerc
February 16, 2013, 8:18pm
2
If someone gets the chance, I would really appreciate it if they could click on ‘update neighbor nodes’ button and let me know the results.
Ideally if you’re moving a single device to a new location, it would be an ideal time to do it and share your log results.
Many Thanks !
sdittoc
February 19, 2013, 12:39am
3
[quote=“parkerc, post:2, topic:174222”]If someone gets the chance, I would really appreciate it if they could click on ‘update neighbor nodes’ button and let me know the results.
Many Thanks ![/quote]
I did this to one of my ge outdoor light modules. I moved it from 25 feet away to 2 foot away from an intermatic Ha05. I clicked “'update neighbor nodes” for the device but it still does not see the ha05. I have two of these for lights outside my garage the one in question on sees 4 devices while the other sees 8. I then did the revers for the ha05 that can only see 4 nodes and told it to heal. Nothing changed. I do not know if this helps you or not. If it is a problem with my Ha05 i am not sure why it would see any nodes…
parkerc
February 19, 2013, 9:14pm
4
Hi @sdittoc
Are you able to share your log results when you click/run the ‘update neighbor node’ button like I did below ?
Using my limited knowledge on my results, it seems to suggest is just went through the motions in 0 seconds (0m) and basically did nothing (now I might be wrong, but unless someone can explain otherwise that’s what it looks like .)
I would be very interested to see what yours shows.
sdittoc
February 20, 2013, 3:23am
5
[quote=“parkerc, post:4, topic:174222”]Hi @sdittoc
I would be very interested to see what yours shows.[/quote]
Can you tell me where to find the log information? When i click on the log tab for the device it takes me to an alert page with no other information on it. If i click on the log tab under setup it just gives me check boxes for configuring logging and usb storage. I have repaired several time and cannot find any info.
parkerc
February 20, 2013, 7:36am
6
Hi @sdittoc
The log file you need is located on Vera here /var/log/cmh/LuaUPnP.log (attain using SSH, or WinSCP)
Have a look at this on how to get there etc. - http://wiki.micasaverde.com/index.php/Logs
Plus there’s a web version too via http://192.xxx.x.xxx/cgi-bin/cmh/log.sh?Device=LuaUPnP
When extracting info, the best way for me is to use WinSCP and access the log file directly …
sdittoc
February 20, 2013, 10:15am
7
[quote=“parkerc, post:6, topic:174222”]Hi @sdittoc
When extracting info, the best way for me is to use WinSCP and access the log file directly …[/quote]
Here you go:
[code]08 02/20/13 5:03:15.476 JobHandler_LuaUPnP::HandleActionRequest device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 action: UpdateNeighbors LEAK this:143360 start:512000 to 0xb07000 <0x2da3f680>
08 02/20/13 5:03:15.476 JobHandler_LuaUPnP::HandleActionRequest argument Device=19 <0x2da3f680>
03 02/20/13 5:03:15.477 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x2da3f680>
06 02/20/13 5:03:15.477 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastHeal was: 1361330164 now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2da3f680>
06 02/20/13 5:03:15.478 Device_Variable::m_szValue_set device: 19 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: NeighborsInverse was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2da3f680>
06 02/20/13 5:03:15.478 Device_Variable::m_szValue_set device: 19 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: Health was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2da3f680>
02 02/20/13 5:03:15.479 ZWJob_HealNetwork::ZWJob_HealNetwork node 15/0x83f7a8 of 1 TO3066: 0 20/0x83f7a8/1 nummin:0 numcycle:0 conf:0 mr:1 only 0 neighb: 0 stage 4 to 0 retry 0 job#893 :heal node dev:1 (0x964e00) P:50 S:0 <0x2da3f680>
02 02/20/13 5:03:15.505 ZWJob_HealNetwork::Run XXX1 <0x2c43f680>
02 02/20/13 5:03:15.505 ZWJob_HealNetwork::CalculateRoutes XXX1 # of hops 0 <0x2c43f680>
02 02/20/13 5:03:15.505 ZWJob_HealNetwork::CalculateRoutes XXX2 node 15 # of hops 0 get tc 1 <0x2c43f680>
02 02/20/13 5:03:15.506 ZWJob_HealNetwork::CalculateRoutes XXX2 node 15 got tc 1 <0x2c43f680>
02 02/20/13 5:03:15.506 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:15.604 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:15.704 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:15.804 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:15.904 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:16.004 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:16.114 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:16.224 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:16.334 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:16.444 ZW_Send_Data node 15 USING ROUTE 255.0.0.0 <0x2c43f680>
02 02/20/13 5:03:16.544 XXX ProfileRoute node 15 255.0.0.0 att:10 succ: 10 avg: 102 max: 195 hops: 0 score=5 <0x2c43f680>
02 02/20/13 5:03:16.544 ZWJob_HealNetwork::CalculateRoutes XXX2 # of hops 0 route 1->255.0.0.0->15 found 1 node 15 edge 0 success 10 of 10, latency avg 102 max 195 wasted 0 score 5 <0x2c43f680>
02 02/20/13 5:03:16.545 ZWJob_HealNetwork::Run XXX1 <0x2c43f680>
02 02/20/13 5:03:16.545 ZWJob_HealNetwork::CalculateRoutes XXX1 # of hops 0 <0x2c43f680>
02 02/20/13 5:03:16.545 ZWJob_HealNetwork::CalculateRoutes XXX2 node 15 # of hops 0 get tc 0 <0x2c43f680>
02 02/20/13 5:03:16.546 ZWJob_HealNetwork::CalculateRoutes XXX2 node 15 # of hops 1 get tc 1 <0x2c43f680>
02 02/20/13 5:03:16.547 AddTestCases XXXX5a comparing 0xa4bc48 <0x2c43f680>
02 02/20/13 5:03:16.547 AddTestCases XXXX5a comparing 0x8377f8 <0x2c43f680>
02 02/20/13 5:03:16.547 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.547 AddTestCases XXXX5a comparing 0x95dec8 <0x2c43f680>
02 02/20/13 5:03:16.548 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.548 AddTestCases XXXX5a comparing 0x94dcb8 <0x2c43f680>
02 02/20/13 5:03:16.548 AddTestCases XXXX5a comparing 0x8faa00 <0x2c43f680>
02 02/20/13 5:03:16.549 AddTestCases XXXX5a comparing 0x8fa5f8 <0x2c43f680>
02 02/20/13 5:03:16.549 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.549 AddTestCases XXXX5a comparing 0x8f1420 <0x2c43f680>
02 02/20/13 5:03:16.550 AddTestCases XXXX5a comparing 0x844cf0 <0x2c43f680>
02 02/20/13 5:03:16.550 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.550 AddTestCases XXXX5a comparing 0x836130 <0x2c43f680>
02 02/20/13 5:03:16.550 AddTestCases XXXX5a comparing 0x82a8e0 <0x2c43f680>
02 02/20/13 5:03:16.551 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.551 AddTestCases XXXX5a comparing 0x9313e8 <0x2c43f680>
02 02/20/13 5:03:16.552 AddTestCases XXXX5a comparing 0x8e8bb0 <0x2c43f680>
02 02/20/13 5:03:16.552 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.552 AddTestCases XXXX5a comparing 0x8f2d98 <0x2c43f680>
02 02/20/13 5:03:16.552 AddTestCases XXXX5a comparing 0x8f7568 <0x2c43f680>
02 02/20/13 5:03:16.553 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.553 AddTestCases XXXX5a comparing 0x83f7a8 <0x2c43f680>
02 02/20/13 5:03:16.553 AddTestCases XXXX5a comparing 0x8f4880 <0x2c43f680>
02 02/20/13 5:03:16.554 AddTestCases XXXX5a comparing 0x951d90 <0x2c43f680>
02 02/20/13 5:03:16.554 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.554 AddTestCases XXXX5a comparing 0x83a958 <0x2c43f680>
02 02/20/13 5:03:16.555 AddTestCases XXXX5ae (nil) <0x2c43f680>
02 02/20/13 5:03:16.555 AddTestCases XXXX5a comparing 0x8ec6d8 <0x2c43f680>
02 02/20/13 5:03:16.555 AddTestCases XXXX5 done adding test cases <0x2c43f680>
02 02/20/13 5:03:16.556 ZWJob_HealNetwork::CalculateRoutes XXX2 node 15 got tc 0 <0x2c43f680>
02 02/20/13 5:03:16.557 ZWJob_HealNetwork::CalculateRoutes XXX6 tested 1 test cases 0 mr 0 <0x2c43f680>
02 02/20/13 5:03:16.557 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 2 no routes <0x2c43f680>
02 02/20/13 5:03:16.557 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 3 no routes <0x2c43f680>
02 02/20/13 5:03:16.557 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 4 no routes <0x2c43f680>
02 02/20/13 5:03:16.558 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 5 no routes <0x2c43f680>
02 02/20/13 5:03:16.558 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 6 no routes <0x2c43f680>
02 02/20/13 5:03:16.558 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 7 no routes <0x2c43f680>
02 02/20/13 5:03:16.558 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 8 no routes <0x2c43f680>
02 02/20/13 5:03:16.559 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 9 no routes <0x2c43f680>
02 02/20/13 5:03:16.559 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 10 no routes <0x2c43f680>
02 02/20/13 5:03:16.559 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 11 no routes <0x2c43f680>
02 02/20/13 5:03:16.559 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 12 no routes <0x2c43f680>
02 02/20/13 5:03:16.560 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 13 no routes <0x2c43f680>
02 02/20/13 5:03:16.560 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 14 no routes <0x2c43f680>
02 02/20/13 5:03:16.560 ZWJob_HealNetwork::ParseCalculateRouteResults node 15 is:
Edge node: 0 score: 5 route: 1->0.0.0.0->15 num hops: 0 Latency avg: 102 max: 195 success 10 of 10
<0x2c43f680>
02 02/20/13 5:03:16.561 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 16 no routes <0x2c43f680>
02 02/20/13 5:03:16.561 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 17 no routes <0x2c43f680>
02 02/20/13 5:03:16.561 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 18 no routes <0x2c43f680>
02 02/20/13 5:03:16.561 ZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 19 no routes <0x2c43f680>
01 02/20/13 5:03:16.562 ZZZZZ node 15 found 1 worst 5 <0x2c43f680>
[/code]
parkerc
February 20, 2013, 8:53pm
8
Thanks @sdittoc
I’m not sure what @OTi edited, but looking at your extract (with limited knowledge) you seem to have something different to me.
Maybe that’s because you are on the latest Vera beta firmware?
I assume you have tried a full system heal to try and solve your issue? From what I have seen so far on my Vera ‘Update Neigbor Nodes’ does not look to do anything.
sdittoc
February 21, 2013, 10:34am
9
[quote=“parkerc, post:8, topic:174222”]Thanks @sdittoc
I assume you have tried a full system heal to try and solve your issue? From what I have seen so far on my Vera ‘Update Neigbor Nodes’ does not look to do anything.[/quote]
Yes, I guess it might have something to do with the new firmware. I have PM OTI to ask what was removed. I have never looked at the logs before until now. I am running the newer firmware because of issues with the new Schlage motorized deadbolt. Thanks,
@sdittoc , @parkerc ,
I think the [tt]Update Neighbor Nodes[/tt] stuff is affected by some of the Z-Wave settings. Could the pair of you post whether you have the following settings checked or unchecked?
[tt]Setup[/tt] > [tt]Z-Wave Settings[/tt] > [tt]Options[/tt]
[tt]Use Z-Wave version 3.20 instead of 2.78 IMPORTANT: Read this first
Use Vera routing instead of Z-Wave (requires 4.5)
Limit neighbors to Z-Wave discovery (requries Vera routing)[/tt]
parkerc
February 21, 2013, 5:41pm
11
@oTI
Here you go
Version 3.20 L:1
Last update N/A
Last Z-Wave network backup 17-FEB-2013 20:34
CHECKED - By default Vera should automatically configure devices
CHECKED - Use Z-Wave version 3.20 instead of 2.78 IMPORTANT: Read this first
CHECKED - Use Vera routing instead of Z-Wave (requires 4.5)
- Limit neighbors to Z-Wave discovery (requries Vera routing)
CHECKED - Poll nodes learn more
Number of seconds to wait to start polling 20
Only poll a node if the Z-Wave network is idle at least 10 seconds.
Unless specified otherwise, poll each node at most once every 60 seconds.
Poll a node every 30 seconds.
sdittoc
February 21, 2013, 11:58pm
12
[quote=“oTi@, post:10, topic:174222”]@sdittoc , @parkerc ,
Limit neighbors to Z-Wave discovery (requries Vera routing)[/tt][/quote]
@oTI
Here you go
Version 3.20 L:1
Last update N/A
Last Z-Wave network backup 18-FEB-2013 14:04
sdittoc
February 24, 2013, 1:20pm
13
For testing purpose I got out one of my GE outdoor modules and placed it inside the house. I did the update neighbor nodes and nothing changed. The device is inside now and the list should have changed. I then did a zwave repair for this node and nothing changed. I then did a zwave repair for a device that it can’t see but should and it did not update either. I have not performed a repair on my entire network. I would think doing what I have done above would update information correctly. My only other thought would be to exclude device and include it again.
Just to chirp in mine also does not work properly, on entire network heal or the button on an individual node, would be great to get a fix for this.
Sent from my HTC HD2 using Tapatalk 2
sdittoc
February 24, 2013, 4:22pm
15
I purchased a spare ha05 device to test with. I unplugged the old one and set aside so i would not mess with schedules etc. installed new device an included I went from seeing 4 devices with the existing device to 9 devices with the new device.
sdittoc
February 24, 2013, 4:24pm
16
[quote=“LightsOn, post:14, topic:174222”]Hi,
Sent from my HTC HD2 using Tapatalk 2[/quote]
I agree. I do not know the history on this… Has anyone ever filled a support request?
parkerc
February 24, 2013, 10:29pm
17
Hi @LightsOn
Would you be able share the results in your log file when you click on the ‘Update Neighbor Nodes’ button - you can see my results in the first post on this thread. I’m not aware of a full system heal having issues, as you receive a report on that - but for this particular thread - it’s focused on the device specific update node (heal) button.
Hi @Parkerc ,
Will do no problem, will take me a couple of days as away but will sort asap, thanks as always for the offer of help here.
Hi @Parkerc
sorry for the delay - hopefuly the below is what you were after?
08 02/26/13 12:04:32.675 JobHandler_LuaUPnP::HandleActionRequest device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 action: e[36;1mUpdateNeighborse[0m <0x30836680>
08 02/26/13 12:04:32.676 JobHandler_LuaUPnP::HandleActionRequest argument Device=39 <0x30836680>
03 02/26/13 12:04:32.707 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x30836680>
06 02/26/13 12:04:32.717 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mLastHeale[0m was: 1361845191 now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x30836680>
06 02/26/13 12:04:32.718 Device_Variable::m_szValue_set device: 39 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mNeighborsInversee[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x30836680>
06 02/26/13 12:04:32.719 Device_Variable::m_szValue_set device: 39 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mHealthe[0m was: now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x30836680>
02 02/26/13 12:04:32.720 e[33;1mZWJob_HealNetwork::ZWJob_HealNetwork node 33/0x856058 of 1 TO3066: 0 20/0x856058/1 nummin:0 numcycle:0 conf:0 mr:1 only 0 neighb: 0 stage 4 to 0 retry 0 job#1738 :heal node (0x10aad90) P:50 S:0e[0m <0x30836680>
02 02/26/13 12:04:32.724 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:32.724 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX1 # of hops 0e[0m <0x2bf4b680>
02 02/26/13 12:04:32.725 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX2 node 33 # of hops 0 get tc 1e[0m <0x2bf4b680>
02 02/26/13 12:04:32.725 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX2 node 33 got tc 1e[0m <0x2bf4b680>
02 02/26/13 12:04:32.726 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:32.987 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
06 02/26/13 12:04:33.007 Device_Variable::m_szValue_set device: 58 service: urn:futzle-com:serviceId:CountdownTimer1 variable: e[35;1mRemaininge[0m was: 555 now: 554 #hooks: 0 upnp: 0 v:0x8a43f8/NONE duplicate:0 <0x2cd4b680>
02 02/26/13 12:04:33.147 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:33.257 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:33.397 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:33.568 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:33.707 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:33.817 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:33.933 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.038 e[33;1mZW_Send_Data node 33 USING ROUTE 255.0.0.0e[0m <0x2bf4b680>
06 02/26/13 12:04:34.101 Device_Variable::m_szValue_set device: 58 service: urn:futzle-com:serviceId:CountdownTimer1 variable: e[35;1mRemaininge[0m was: 554 now: 553 #hooks: 0 upnp: 0 v:0x8a43f8/NONE duplicate:0 <0x2cd4b680>
02 02/26/13 12:04:34.147 e[33;1mXXX ProfileRoute node 33 255.0.0.0 att:10 succ: 8 avg: 123 max: 159 hops: 0 score=45e[0m <0x2bf4b680>
02 02/26/13 12:04:34.148 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX2 # of hops 0 route 1->255.0.0.0->33 found 1 node 33 edge 0 success 8 of 10, latency avg 123 max 159 wasted 432 score 45e[0m <0x2bf4b680>
02 02/26/13 12:04:34.149 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.149 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX1 # of hops 0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.150 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX2 node 33 # of hops 0 get tc 0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.151 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX2 node 33 # of hops 1 get tc 1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.152 e[33;1mAddTestCases XXXX5a comparing 0x864f40e[0m <0x2bf4b680>
02 02/26/13 12:04:34.152 e[33;1mAddTestCases XXXX5a comparing 0x9ac898e[0m <0x2bf4b680>
02 02/26/13 12:04:34.152 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.152 e[33;1mAddTestCases XXXX5a comparing 0xa1ee90e[0m <0x2bf4b680>
02 02/26/13 12:04:34.153 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.153 e[33;1mAddTestCases XXXX5a comparing 0x874a38e[0m <0x2bf4b680>
02 02/26/13 12:04:34.154 e[33;1mAddTestCases XXXX5a comparing 0x848030e[0m <0x2bf4b680>
02 02/26/13 12:04:34.154 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.154 e[33;1mAddTestCases XXXX5a comparing 0x926f48e[0m <0x2bf4b680>
02 02/26/13 12:04:34.155 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.155 e[33;1mAddTestCases XXXX5a comparing 0x752180e[0m <0x2bf4b680>
02 02/26/13 12:04:34.156 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.156 e[33;1mAddTestCases XXXX5a comparing 0x8ef6b8e[0m <0x2bf4b680>
02 02/26/13 12:04:34.157 e[33;1mAddTestCases XXXX5a comparing 0x8c8728e[0m <0x2bf4b680>
02 02/26/13 12:04:34.158 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.158 e[33;1mAddTestCases XXXX5a comparing 0x837398e[0m <0x2bf4b680>
02 02/26/13 12:04:34.159 e[33;1mAddTestCases XXXX5a comparing 0x8b31f8e[0m <0x2bf4b680>
02 02/26/13 12:04:34.159 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.159 e[33;1mAddTestCases XXXX5a comparing 0x82adb8e[0m <0x2bf4b680>
02 02/26/13 12:04:34.160 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.160 e[33;1mAddTestCases XXXX5a comparing 0x834c70e[0m <0x2bf4b680>
02 02/26/13 12:04:34.161 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.162 e[33;1mAddTestCases XXXX5a comparing 0x8f9f70e[0m <0x2bf4b680>
02 02/26/13 12:04:34.163 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.163 e[33;1mAddTestCases XXXX5a comparing 0x856058e[0m <0x2bf4b680>
02 02/26/13 12:04:34.163 e[33;1mAddTestCases XXXX5a comparing 0x8537e0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.164 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.164 e[33;1mAddTestCases XXXX5a comparing 0x8693b0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.165 e[33;1mAddTestCases XXXX5a comparing 0x8fa128e[0m <0x2bf4b680>
02 02/26/13 12:04:34.165 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.165 e[33;1mAddTestCases XXXX5a comparing 0x827ad0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.166 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.166 e[33;1mAddTestCases XXXX5a comparing 0x85f5e0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.167 e[33;1mAddTestCases XXXX5a comparing 0x826cf0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.167 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.168 e[33;1mAddTestCases XXXX5a comparing 0x8752a0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.168 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.168 e[33;1mAddTestCases XXXX5a comparing 0x8687b8e[0m <0x2bf4b680>
02 02/26/13 12:04:34.169 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.169 e[33;1mAddTestCases XXXX5a comparing 0x86ff80e[0m <0x2bf4b680>
02 02/26/13 12:04:34.170 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.170 e[33;1mAddTestCases XXXX5a comparing 0x820400e[0m <0x2bf4b680>
02 02/26/13 12:04:34.177 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.178 e[33;1mAddTestCases XXXX5a comparing 0x85e410e[0m <0x2bf4b680>
02 02/26/13 12:04:34.178 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.179 e[33;1mAddTestCases XXXX5a comparing 0x85f7c0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.179 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.179 e[33;1mAddTestCases XXXX5a comparing 0x878e68e[0m <0x2bf4b680>
02 02/26/13 12:04:34.180 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.180 e[33;1mAddTestCases XXXX5a comparing 0x8552d0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.181 e[33;1mAddTestCases XXXX5a comparing 0x8611d8e[0m <0x2bf4b680>
02 02/26/13 12:04:34.181 e[33;1mAddTestCases XXXX5ae (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.181 e[33;1mAddTestCases XXXX5 done adding test casese[0m <0x2bf4b680>
02 02/26/13 12:04:34.182 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX2 node 33 got tc 0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.224 e[33;1mZWJob_HealNetwork::CalculateRoutes XXX6 tested 1 test cases 0 mr 0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.224 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 2 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.224 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 3 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.225 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 4 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.225 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 5 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.226 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 6 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.226 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 9 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.226 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 10 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.227 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 11 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.227 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 13 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.228 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 14 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.228 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 17 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.229 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 26 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.229 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 32 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.230 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults node 33 is:
Edge node: 0 score: 45 route: 1->0.0.0.0->33 num hops: 0 Latency avg: 123 max: 159 success 8 of 10
e[0m <0x2bf4b680>
02 02/26/13 12:04:34.231 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 40 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.231 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 41 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.231 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 43 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.232 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 52 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.232 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 59 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.232 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 62 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.233 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 63 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.233 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 64 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.233 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 65 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.234 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 67 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.234 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 68 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.234 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 69 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.235 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 72 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.235 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 73 no routese[0m <0x2bf4b680>
02 02/26/13 12:04:34.235 e[33;1mZWJob_HealNetwork::ParseCalculateRouteResults XXX6 results node 74 no routese[0m <0x2bf4b680>
01 02/26/13 12:04:34.237 e[31;1mZZZZZ node 33 found 1 worst 45e[0m <0x2bf4b680>
01 02/26/13 12:04:34.237 e[31;1mZZZZZ route #0 node 33->0.0.0.0->gw score 45e[0m <0x2bf4b680>
06 02/26/13 12:04:34.238 Device_Variable::m_szValue_set device: 39 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mAutoRoutee[0m was: 52-20x,6-25x,11-26x,32.72-36x now: 0-45 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bf4b680>
06 02/26/13 12:04:34.239 Device_Variable::m_szValue_set device: 39 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mAllRoutesFailede[0m was: 1 now: 0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bf4b680>
01 02/26/13 12:04:34.239 e[31;1mZZZZZ route node 33=0-45e[0m <0x2bf4b680>
02 02/26/13 12:04:34.240 e[33;1mUpdateManualRoute XXX1 node 33 route 0-45e[0m <0x2bf4b680>
02 02/26/13 12:04:34.241 e[33;1mUpdateManualRoute XXX2 direct 0-45e[0m <0x2bf4b680>
02 02/26/13 12:04:34.242 e[33;1mZW_Send_Data node 33 USING ROUTE 255.72.0.0e[0m <0x2bf4b680>
02 02/26/13 12:04:34.242 e[33;1mAddAssignReturnRoutes node 33 = 1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.243 e[33;1mZW_Send_Data node 33 USING ROUTE 255.72.0.0e[0m <0x2bf4b680>
06 02/26/13 12:04:34.538 Device_Variable::m_szValue_set device: 39 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: e[35;1mNodeInfoe[0m was: 26,27,72,75,82,85,86,87, now: 26,27,72,75,82,85,86,87, #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2bb4b680>
04 02/26/13 12:04:34.540 <0x2bb4b680>
02 02/26/13 12:04:34.541 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.542 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.543 e[33;1mZZZ m_pZWJob_Base_Current_assign (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.544 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX3e[0m <0x2bf4b680>
02 02/26/13 12:04:34.545 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.545 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.547 e[33;1mZZZ m_pZWJob_Base_Current_assign (nil)e[0m <0x2bf4b680>
02 02/26/13 12:04:34.549 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX3e[0m <0x2bf4b680>
02 02/26/13 12:04:34.550 e[33;1mZWJob_HealNetwork::Run XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.550 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX1e[0m <0x2bf4b680>
02 02/26/13 12:04:34.550 e[33;1mZWJob_HealNetwork::DumpResult XXX3e[0m <0x2bf4b680>
02 02/26/13 12:04:34.810 e[33;1mZWJob_HealNetwork::LogJob 3428248/OK:3428248 e[0m <0x2bf4b680>
02 02/26/13 12:04:34.812 e[33;1mZWJob_HealNetwork::DumpResult m_mapHealNetworkStressTest=0e[0m <0x2bf4b680>
06 02/26/13 12:04:34.896 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mLastHeale[0m was: now: 1361880274 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2bf4b680>
04 02/26/13 12:04:34.900 <0x2bf4b680>
03 02/26/13 12:04:34.901 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 0 <0x2bf4b680>
02 02/26/13 12:04:34.902 e[33;1mZWJob_HealNetwork::MoveToNextStage XXX2e[0m <0x2bf4b680>
parkerc
February 26, 2013, 7:14pm
20
Thanks @LighrtsOn
I’m looking at this with very limited knowledge, but I think yours worked? However can I ask - did you move that device 39 (node 33) to a new location and then click the update neighbor nodes button? Or did it stay in the same (known) location?
