Unwanted alerts
I am running v1.5.622. I am getting email alerts when a light (call it Light1) is turned on or turned off. I do not have any notifications defined for the Light1 device. I do I get it to stop?
If you get notifications then somewhere the ‘notify’ flag got set for that device.
Has this light always generated notifications or is it something that just started happening? If the latter, did you create or edit any scenes around that time? If yes, verify those scenes. If it always happened, you may wish to remove that light and re-add it to Vera to see if that fixes the behavior.
  • Have you checked the Notifications tab for that light?
  • Is any scene using that light? If so, double check the scene’s triggers tab and make sure there is no check for the optional notification.
