Try having the scene that is activated explicitly turn on and off the LED lights. I found that this was the only way I could get the controller to function consistently. Whatever your on scene is, go to the advanced tab, select the scene controller, select SetLight as the operation, new value set to 0 to turn off the LED and 1 to turn on the LED, and then Indicator to the LED button number 1st =1, 2nd = 2.
Here are more details about what I discovered with using a Leviton 4 scene controller. It’s now working consistently. I also added triggers for scenes to turn on the LED light is I turn it on using the regular z-wave wall switch instead of the controller.
Good luck!
Info was taken from my post in this thread:
http://forum.micasaverde.com/index.php/topic,22379.msg167428.html#msg167428
[quote=“kenray536, post:13, topic:178757”][quote=“greysonmorrow, post:8, topic:178757”]Thank you all for the replies. So in theory, if I tie the wires together for an always on experience and use the GE 45631, linked below, it will work?
[url=http://www.amazon.com/gp/product/B003OUWABU/ref=s9_simh_se_p60_d0_i3?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=auto-no-results-center-1&pf_rd_r=1V3KXA0WZ1GCHZEQ7Y8K&pf_rd_t=301&pf_rd_p=1263465782&pf_rd_i=VRCS4-MRX]http://www.amazon.com/gp/product/B003OUWABU/ref=s9_simh_se_p60_d0_i3?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=auto-no-results-center-1&pf_rd_r=1V3KXA0WZ1GCHZEQ7Y8K&pf_rd_t=301&pf_rd_p=1263465782&pf_rd_i=VRCS4-MRX[/url]
I found the Leviton switch, but that is $144. Just hoping to save a little bit of money.
[url=http://www.homedepot.com/p/Leviton-Vizia-RF-4-Button-Scene-Controller-White-031-VRCS4-M0Z/100662458#.Us_rq3k7CdI]http://www.homedepot.com/p/Leviton-Vizia-RF-4-Button-Scene-Controller-White-031-VRCS4-M0Z/100662458#.Us_rq3k7CdI[/url][/quote]
I am using the Leviton switch that you mentioned the VRCS4-M0Z. My switch was controlling an outlet, so I tied the line and load wires together to make it always be on.
I have the top button controlling the philips hue bulb via an On Scene and turning it off via an off scene. The LED lights can be flaky causing them not to go on and off properly. This will cause the controller to get confused at times. To get around this, within the advanced tab of the scene, I select the controller and set it to explicity turn the LED light on or off depending on which scene I am running.
I have the 2nd and 3rd buttons running each running single scene that turn on/off my Kitchen and dining table lights. I’ve found that on these two scenes, the dimmer up and dimmer down buttons always work. The key is to use the setloadleveltarget in the advanced tab. This appears to put the switch/light into a mode where it allows the dimming via the buttons.
The 4th light runs an advanced Hue scene that turns on a total of 6 hues lights to the color and dim level I want and also turns off all other lights.
I’ve been running this setup for about 3 weeks now and it’s been great! The reponse time of the top hue button has been very fast for me with the light turning on 1 to 2 seconds after I hit the button. My controller is about 40 feet from the switch between 2 walls.
The controller was a little tricky to pair but easy to configure once it was added to the z-wave network. I have a seperate on/off scene for each button (8 total). And I make sure to explicity turn on/off the scene controller LED lights in order to make sure that my status is always correct and the scene is controller is in sync. I also have triggers on the kitchen and dimmer lights that set the scene controller LEDs to the correct status in case someone turns the lights on via the normal wall switch.
I bought mine from Amazon:
There is also a more expensive version of the switch that you can buy that has local load control if you don’t want to tie the two wires together. I believe you lose functioning of one of the buttons on the swich if you do this though.
