I have a GE outlet that is controlled by a Leviton wall switch, using scenes configured in my Vera Lite. The GE outlet and Leviton switch are of course both z-wave devices, and both are included in the z-wave network, for which the Vera is the primary controller.
When I first set this up several months ago, it worked consistently, though often with a delay of 1-5 seconds. Pressing the Leviton switch turns a light on, and after a little while, Vera’s scene execution turns on a second light that is plugged into the GE outlet. Pressing the Leviton switch again turns of the directly-connected light, then seconds later the other light turns off. The delay was a bit annoying, since it would often wait just long enough for me to wonder if it was going to work… but it worked consistently so I wasn’t terribly disappointed.
This is set up in a little-used area of my house. When my wife pressed the Leviton switch the other day, only the directly-connected light turned on - the light that’s plugged into the GE outlet remained off. We tried this several times and the GE switch rarely toggled. Sometimes it would respond, usually it would not.
I can control the GE outlet from the Vera’s web UI. Sometimes there is a delay, but it always works, and the delay is no more or less than the delay that I see when controlling over z-wave devices via Vera’s web UI usually about a second, sometimes 2-3 seconds.
When I operate the Leviton switch from the Vera’s web UI, the switch toggles after a second or three, and then the GE outlet toggles almost instantly, in accordance with the scene.
When I operate the Leviton switch by pressing it with my finger, the GE outlet’s behavior is hit-or-miss. At one point today it worked consistently a few times in a row, and I thought the problem was solved… but a few minutes later it mostly just didn’t respond.
I have about 35 devices in my z-wave network, if that matters. I added an Aeon 4-in-1 sensor yesterday, and a Leviton 4-button scene controller fell off the network a few weeks ago and had to be re-added, but the other devices have all been part of the network (and permanently mounted) for a few months at least.
Is this sort of unpredictability common with the GE outlets, Leviton wall switches, and/or the Vera Lite?
Is there a way to get a Leviton switch to control a GE outlet directly, rather than depending on the Vera’s scene execution? I tried setting an association in the Leviton switch, but then I got a red error message at the bottom of the switch icon in the Vera UI, with a message saying that the association failed to configure. It was also tempting to set the “controlled via” option for the GE outlet to be the Leviton switch, but trying to set that up that leads to a “you may brick your Vera” warning, which scared me away from the idea.
Thanks in advance for any insights you all might have!
