I have a door strike powered through an Elk M1 output.
I want to program an F key on the keypad to fire this output, but only if a code is first entered.
I tried checking the use code box on the F key assignment. But after the code is entered and the door unlocks, I don’t need a code to open a second time.
So what is a better way to to do this securely?
