Understanding Triggers
Good Morning for all !
I’m trying understand the concept of triggers…
when I’m in the trigger’s screen to add one nem…in devices I can see many devices, devices I do not have…, and some are scene_controler…how can I discover the correct scene controller I have ??? I have 2 only. but I don’t know in the list what scene_controller is the mines.
after this is cleared…I want create a trigger to when a scene is activated one scene created in my hand held controller GE 45601 be activated, this scene is saved in buttom 1 of scenes.
if someone is disposed to help me…I will be grateful.
Did you not rename your devices/controllers after inclusion?
I think this was my fault.
have now something to identify , I can see vera3 not give one information about the real devices I have running.
do you have some tip for me, friend ?
Not sure where you’re currently at with this. Were you able to set up the trigger / is there still a(nother) problem?
I still with many devices listed in vera3 but I have only 3. only resetting vera3 to factory default will solve this ?
thanks !
If it is a non-Z-Wave device, you can use the trash can to delete it.
If it is a Z-Wave device, you can also use the trash can to delete it, if the device is not present/‘visible’ on the Z-Wave network (anymore); otherwise it will come back (and you’ll have to do an exclusion).
