I had a Trane thermostat (Zwave) on my old house worked great. It was the typical 5 wore setup.
Well I moved and the new house is energy efficient. Great, but when I went to reinstall the trade I noticed that the new Thermo has three wires. Not being familiar with this I had an AC guy confirm that my Trane isn’t compatible.
On the Amazon link you specified one of the notes states:
2.This item requires a common wire (5th wire) to power the unit. Without the common wire this unit will not power up. Instructions as well as a wire saver module are provided with the unit.
Since you only have 3 wires, chances are it may not work. Also Amazon has put this notice on the page:
Item Under Review
While this item is available from other marketplace sellers on this page, it is not currently offered by Amazon.com because customers have told us there may be something wrong with our inventory of the item, the way we are shipping it, or the way it’s described here. (Thanks for the tip!)
We’re working to fix the problem as quickly as possible.
Your best bet is to provide ServiceXP with the make and model number of both your internal and outdoor unit.
You have to buy an interface from Trane to convert this stat to one that can wire into a standard A/C system. I had to go to a Trane dealer to get one.
Trane also make a new zwave stat: TZEMT400BB3NX
