Undefined index: log_path in... when on location page
I have factory reinstated my Vera 2 (1.5.622) and everything is working fine for the most part. I tried some scenes using sunset and sunrise and they didn’t fire as expected behaving completely randomly.
I’ve gone in to check the location settings this evening and I get the following error.
Notice: Undefined index: log_path in /var/www/vhosts/download.mios.com/lib/utils.php on line 34 Database error.
Anyone seen that before?
P.S USB drive activated for logging.
[quote=“xbmcnut, post:1, topic:185666”]Anyone seen that before?
P.S USB drive activated for logging.[/quote]
Why yes…yes I have. :wink: Just last night I set-up new vera-lite with UI5 (same firmware, 1.5.622), and I’m getting the same message. I already sent an inquiry with Vera…we’ll see what they say.
It’s at least somewhat comforting to know this isn’t just me.
There was a server side issue that Vera has addressed on their end. They appear to have implemented a temporary work around for the problem, with a permanent solution in the works:
It was actually on the server side, not on the gateway, so it should be fixed for everyone who was encountering it.
The sysadmin who looked into it said it is possible it may show up again, but he is looking for a permanent solution. But please do let me know if you see it again.
It takes a while for the location drop-downs to appear so you can select your city, but it is functional.
Kudos to the Vera support team for identifying and resolving (at least for now) the issue!
Thanks for the prompt reply! Good to know I didn’t break anything for a change. ;D
