Unarm siren with Minikey Pad Home-mode
I have a little “problem” that I hope you guys might help me with.
I have a Vera Edge, a door sensor, a mini keypad with a tag, the app Housemode Plugin and a siren in the scen I want to create.
I can arm and disarm the sensor via the Mini keypad using a tag and the app (Housemode Plugin)…and when I open the door the siren sounds loud after 15sec…everything is fine so far :slight_smile:
But I want to open the door and be able to turn off the whole scenario with out the siren shouting.
I tried to set a delay for the door sensor (15 sec) so it will give me time to change the mode on the minikey pad to Home-mode and I can also see the door sensor get disarmed…but the siren will shout anyway after 15sec.
Do you know how I can make the siren to forget the first commando (shout within 15sec if the door-sensor opens). And it shall of course shout if someone doesn?t set the minikey pad to Homemode within 15sec.
I have also tried the Veras builtin Home-Away…arm sensor works just fine…but not to unarm the siren within 15 sec when I open the door.
I am novice when it comes to this…
Thank you for your help
Thomas
