Unable to login to MIOS
Hi I am unable to login to MIOS web page, it keeps giving me page cannot be display. however, I am able to login via SQconnect but not the webpage from cp.mios.com, can anyone assist? Thanks.
SQRemote uses a different way to access your Vera remotely. Let me rephrase that, cp.mios.com will use the same url as SQRemote, but what I need to know is if you are having issues logging into cp.mios.com before trying to access you vera unit? What version of Vera firmware are you running? Are you on UI5 or UI4?
  • Garrett
Hi Garrett, Thanks for the reply. Yes, I am facing the issue when using remote login when I login to cp.mios.com after I click login, the system logs in but can’t display any UI. I am using UI5 for Vera 3 and as for firmware, when I am home which I could login to the system, believe it is due to same network therefore I could login, the system prompts me to update firmware, howver I can’t upgrade whenerever I click upgrade to english in UI5.
Suddenly unable to login as well. I get a blank (no devices or rooms) When I try to login on that page I get login failed? Was working this morning???
