I have not tried searching all over and have easily put more than 12 hours trying to get this to work (?!).
My scenario is that I have the Vera as primary controller, with several different activators (mostly Fibaro on/off built in switches) and am now trying to get the Z-Wave.Me 4 Wall controller to work with my new Fibaro dimmers.
For the four different buttoms I would like to be able to turn both dimmers to 0%, 25%, 50% and 100%. I have tried several different configurations, both using guide in Vera which seems to have failed completely and then trying to manually set the configurations.
I managed to get the On/Off switches to work by using association for group 1/2, but when I changed the device id to the dimmers, nothing happens.
I have also tried to configure the 4 Button wall controller to send scenarios and connected them with the right scenario in Vera, but when I do this, the key fob refuses to be configured correctly and usually stops at “Setting special associations”. When I remove the scene connections in Vera the wall controllers gets configured correctly (I have tried with my two different wall controllers).
Not sure what to do, but I am getting to the point where I want to throw away the wall controllers and just install a new manual switch to get it to work. Right now I need my phone to turn on/off/dim the lights!
Any help as REALLY apprechiated… ![]()
Thanks.
