Unable to create trigger. No devices listed
I just installed PLEG and have the device properly showing up on UI7. After reading some of the documentation, I tried creating my first trigger (to notify me when my garage door was left open) and I cannot see any devices in the inputs → triggers tab. I do see my rooms listed, however there are no devices. Can someone please tell me how to fix this?
Thanks,
Andy
Nevermind! I just found my problem was that I was using Chrome. I tried Firefox and all devices are now showing up!
Chrome works just fine.
You just needed to do the Vera TWO Step:
  1. Reload Vera
  2. Reload your Browser.
I’m having the same problem. Only “rooms” are showing up in the select device drop down box for triggers. I’ve reloaded both Firefox and Safari and rebooted the Vera Plus. No change. Any other ideas?
Did you upgrade from UI5 ?
If so did you upgrade the plugins ?
Remember to do the Vera TWO Step AFTER upgrading the plugins ?
Richard,
I continue to have issues with Chrome even though I have rebooted and refreshed. FF and Safari work fine. Just FYI.
Andy
[quote=“RichardTSchaefer, post:5, topic:191184”]Did you upgrade from UI5 ?
Remember to do the Vera TWO Step AFTER upgrading the plugins ?[/quote]
Hi Richard,
Yes, at least as far as I can tell. The PLC is showing v7.48 and PLEG is v7.47. There’s no “Update App” button showing for the PLC app but there is one for PLEG and I did click on it and waited several minutes for the update to be applied. I also did the Vera 2 step in both FireFox and Safari and rebooted Vera Plus. I’ll try anything else you can think of. I really don’t want to uninstall and start from scratch. Thanks.
IF YOU UPGRADE FROM UI5 TO UI7 YOU MUST UPGRADE THE PLUGINS EVEN IF YOU ARE ON THE LATEST VERSION!
The code for UI7 is different then the code for UI5.
See:
http://forum.micasaverde.com/index.php/topic,14446.msg258371.html#new
[quote=“RichardTSchaefer, post:8, topic:191184”]IF YOU UPGRADE FROM UI5 TO UI7 YOU MUST UPGRADE THE PLUGINS EVEN IF YOU ARE ON THE LATEST VERSION!
See:
http://forum.micasaverde.com/index.php/topic,14446.msg258371.html#new[/quote]
Okay. Perhaps what you’re telling me to do and what I’m interpreting it to be aren’t the same thing. Here is what I have done up to this point:
On my PLC page, there is no capability to update the app. There is an “Auto Update” checkbox and it is checked. It shows the current version as v7.48.
On my PLEG page, there is an “Update App” button and I clicked on it and got a message "Update App command sent successfully. The current version shown is v7.47.
For both pages, I reloaded the Browser window and I also rebooted the Vera Plus by going to Setting>>Net & WiFi>>Reboot.
Nothing changed. I still have the message at the top of the browser saying: “PLEG[49] : tKitchenDoorOpened AND pDayOrNight == 0: Invalid Value token: TKITCHENDOOROPENED”
Next I followed your steps for upgrading via the following http commands:
http://10.0.1.30:3480/data_request?id=update_plugin&Plugin=3066
http://10.0.1.30:3480/data_request?id=update_plugin&Plugin=3086
Both returned “OK”
I reloaded the browser and rebooted the Vera Plus. Still getting the same message as above.
Finally, I downloaded your file, “J_ProgramLogicC-UI7-NEW.js.txt” and renamed it to “J_ProgramLogic.js” and uploaded it to Vera. I reloaded the browser, rebooted Vera but still the same message. However, now the “Trigger” section is working! YAY!! I assume the message will go away once I redefine the missing trigger.
One thing I noticed when I click on the “Report” or “Status” button. I get the following header:
PLEG[49] 2016-02-23 19:47:58.197 PLC Version:7.46
The version info seems to be wrong.
THANKS again for all your help. Hopefully, this will take care of it. :slight_smile:
EDIT: Just added the old triggers and the errors disappeared. YES!! ;D
