Just got a new Vera Lite ;D and was trying to move my Z-Wave settings from the Honeywell Tuxedo panel to Vera.
I imported all the settings to Vera and then did a backup, factory reset on the Honeywell & Vera to make the Vera primary.
After I imported the zwave settings on the vera lite, the trane thermostat no longer shows up on the Vera unit or the Honeywell and i’m unable to clear the Z-Wave paring on the thermostat
I have unplugged the Trane from the wall and let it sit overnight, still no luck in clearing the settings. Trane/Nexia team is of no luck as they dont support anything but Nexia gateways
Appreciate if there is a way to clear the zwave settings or would i have to buy another thermostat as a replacement ? If so, any recommendations other than Trane that work well ?
