For some reason when I go into the Devices section, then try to add a Generic Zigbee device the Vera no longer works properly. It used to pop up a blue bar at the top saying “Zigbee: Addnode” or something like that, but now it just sits there with the small green spinning GIF and doesn’t do anything. If I pick something specific like the GE 19 zigbee bulb it does allow me to try and it shows “Zigbee: Addnode” at the top. Any idea why the generic zigbee device fails?
After about a minute the GIF disappears and the UI says [Exit] or [Retry]
I’ve already rebooted twice via the UI, and even tried a hard reboot with a power pull but it doesn’t seem to help.
I tried a couple browsers as well to no avail.
I do occasionally get the blue bar but it says “Configuring Z-Wave devices” and goes away a little bit later.
