Yes, you’re absolutely certainly right (I’m reading a lot from you and you have such a technical level that I won’t contradict you).
An implementation file is missing too, and I don’t understand why as I restored from a previous and safe backup.
D_FUP_uuid… It’s generating a “system error” on “device 204”…
I asked support for that, but no answer since I reached them on 11/05…
It sounds like you are using the TCP yamaha plugin. If another utility was connected it may be the issue since TCP. allows for only one connection at a time. I used the tcp plugin in the past any was actually the one to add zone 3 support. I had switched to the HTTP plugin since I could not connect my former iRule interface and Vera concurrently.
Compare the functionality of both. If the HTTP plugin will do everything you need it to I see no reason to use both. Plus with HTTP you will not have the limitation of one connection.
[Meta] Everyone, IMO, this topic has gotten too long and has drifted off-topic too many times.
At this point:
if you are having problems getting your Vera up on 7.0.29, that should be discussed in a separate topic (or topics, as there have been many related in the General Vera Discussions category);
If you are having problems with a specific device or class of devices, those should be in separate topics, within the category best-matching your device.
In all cases, if the issue relates to 7.0.29 specifically, call that out in the topic title.
The way different threads of discussion are being interspersed in this topic makes it more difficult for users to follow and glean out any gems that may help them, and more difficult for Vera to follow a thread of discussion on any one particular issue that can help them understand something they may need to address.
I think there’s some reticence on the part of many users to start new topics. Please, go for it. And those of us that are “mods” of a sort, please be polite when people aren’t posting in the correct location–I don’t think @Sorin will object to us taking the initiative and separating those new issues to the new topics they deserve and keeping these forums more organized for the benefit of all.
And on that note, I’m going to assume privilege and close this topic. If @Sorin wishes to keep it open, he can re-open it, but I think closing it will help encourage new topics and reduce the drifting afield and beating of expired equines here.
Hello,
Any news about new update? Last was in April… A lot of new devices doesn’t work correctly. How about Smart Implant compatibility? There aren’t that kind of device on market. Before was Universal Binary Sensor but for now you can’t buy it.
An update on my VeraPlus running 7.29 - I have narrowed it down to the wi-fi. I had to restore network, than do factory reset to recover the VeraPlus, twice. Third time, I left it plugged into the network and it working perfectly. By the way, the home wi-fi is working fine. The VP is plugged into an Netgear 6000 that is connected to the main 7000 router via 5G. Definitely the VP wi-fi is suddenly broken.
